Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-21-2025 06:24 AM
J'avais réinitialisé mon Chromecast et en changeant la date de mon téléphone avant le 9 mars (astuce donnée sur la communauté ) mon chromecast remarche avec Google home. Dois faire cette mise a jour que vous proposez ou bien laissez comme tel. Merci de me répondre
03-21-2025 07:35 AM
This is just not ok.. have followed your directions for those who did hit reset. Upgraded to 3.30.1.6 for Android and started up. Get through to the point where it needs to connect wifi and then receives the message " cant establish connection to Chromecast. Make sure you are close to the device and that you establish connection when asked". I have now been without tv for past 10+ days waiting for the fix. If my chromecast 2gen is broken i can guarentee you i will not buy another google device from you.. will move to another supplier
03-21-2025 08:10 AM - edited 03-21-2025 08:15 AM
So, apparently my 2nd gen Chromecast was updated. But now streaming playback takes minutes to load instead of seconds, and videos from Plex only stream for a few minutes before going into endless loading or choppy playback loading every couple of seconds. My Plex server streams to my Chromebook and PC without issues.
This is NOT a fix. The degraded performance has nothing to do with anything but incompetence or greed.
03-21-2025 11:28 AM
You rolled out the fix for Chromecast Audio and everything worked good for about 2 days. Now everything is broken worse than before.
03-21-2025 04:14 PM
Mine too!
03-21-2025 11:33 AM
One of mine worked for a few days after the fix, and then stopped working again, unable to connect.
The other one (which i factory reset before you made this forum announcement) has not worked since the initial day this started.
Support says google is apparently aware of the issue and to wait, but this forum post says it's been fixed. So which is it? fixed or not? Because it's not fixed for both of my chromecast gen 2s.
03-21-2025 11:56 AM
But what if we DID factory reset? Ours is trying to connect, but Google audio device is not an option to choose on the device list??? Please advise. We miss it!
03-21-2025 12:47 PM
it does work but you may have to update google home in stages up to the version 16. And then it works.
03-21-2025 12:14 PM
conectar
03-21-2025 12:15 PM
Conéctar
03-21-2025 12:51 PM
This may or may not apply to you but …it does work but you may have to update google home in stages up to the version 16. And then it works.
03-21-2025 12:15 PM
That worked for me, thanks! Updated App, added device, which connected OK this time and ran the firmware update on the chromecast. Result!
03-21-2025 02:07 PM
Tiktok account
03-21-2025 02:51 PM
Everything updated, following the instructions, both Google Home app and Google Chromecast, but it still doesn't work!
03-21-2025 03:10 PM
i am not able to update the chromecast after i factory reset it is immdiatly giving me s network problem and update failure
03-21-2025 06:29 PM
I’ve trying everything but it’s not working with me
03-21-2025 07:05 PM
03-21-2025 08:53 PM
Yo desde mi mobile ingrese a la apliación de Playstore para buscar en home / update
Actualice y luego volvi a agregar el dispositivo de Chromecast, y de forma automatica conecto y actualizo mi dispositivo. Y ya esta funcionando muy bien!
03-22-2025 02:27 PM
Gracias por tu comentario, hice lo mismo con App Store y acaba de comenzar a funcionar!
03-21-2025 09:12 PM
Thanks
03-22-2025 04:25 AM
Still doesn't work for me.
Have followed your directions for those who did hit reset.
Get through to the point where it needs to connect wifi and then receives the message: " cant establish connection to Chromecast. Make sure you are close to the device and that you establish connection when asked".
I have now been unable to use my Chromecast for the past 10+ days waiting for the fix.
Hopefully you have a working fix soon - If my Chromecast 2gen is broken i can guarantee you i will not buy another google device from you.. will move to another supplier.
03-22-2025 09:33 AM
I just updated my second generation chromecast and Google home speaker.
03-22-2025 09:23 AM
BOYE ELHADJI
03-22-2025 09:32 AM
It all works again
03-22-2025 10:30 AM
03-22-2025 12:21 PM - edited 03-22-2025 12:22 PM
22/03/2025 in precedenza al problema senza saperlo avevo fatto reset oggi anche se sul sito non c'era scritto nulla ho riprovato ad riassociare il dispositivo gen2 e in automatico ha fatto aggiornamento in automatico anche voi rifunzina tutto
03-22-2025 01:55 PM
Two weeks without working, how long do we have to wait? Amazing, who was a techie for so many days!
03-22-2025 02:04 PM
Two weeks without working, how long do we have to wait? Incredible that in this technological age it takes so many days!
03-22-2025 02:04 PM
We got the update on our phone yesterday. Factory reset the chromecast audio and went through the setup process in the Home app. Its working!
03-22-2025 02:11 PM
I'm a little confused. Does this mean my device was affected?
03-22-2025 02:39 PM
03-22-2025 02:40 PM
03492728351
03-22-2025 02:40 PM
sultanjan
03-22-2025 02:41 PM
Salman110
03-22-2025 03:10 PM
No puedo iniciar sesión
03-22-2025 03:11 PM
03-22-2025 04:52 PM
Olá, estava funcionando novamente, porém hoje voltou a ficar com problemas. Não consigo reproduzir a tela do dispositivo Android no Chromecast 2nd gen
03-22-2025 05:45 PM
aún es hora que no puedo configurar cromecast me cambiaré a firestick Amazon
03-23-2025 02:49 AM
Rajadewa138
03-23-2025 02:50 AM
