Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-11-2025 12:10 PM
Any news? Since 2 day we can't use it ...2 DAYS!!!
03-11-2025 12:11 PM
Stop trying fix this issue. Wait Google fix
03-11-2025 12:14 PM
Just came here...seems global...So Google is aware and fixing it ? Thanks
03-11-2025 12:10 PM
In Italian "impossibile autenticare" (unable to authenticate) WTF is going on. Already factory reset. What I should do ??
03-11-2025 12:19 PM
ciao, io ho seguito le istruzioni di anonymus, ho impostato una data antecedente a domenica scorsa sul telefono e sono riuscita a riconfigurare il Chromecast su google home. adesso vedo infatti lo screensaver del chromecast sulla tv. ovviamente attualmente è impossibile avviare lo streaming.
03-11-2025 12:12 PM
do we have any ETA?
03-11-2025 12:13 PM
Please fix ASAP, our tv so old it's the only way we can watch.
03-11-2025 12:16 PM
Ok. Waiting for fix it
Thanksss
03-11-2025 12:19 PM
Its crazy its been 2 days and this hasnt been fixed, how the **bleep** is my physical product bricked because an expired certificate happened, like just means even if my device works for the next 20 years you can forcibly make my device useless just by denying certificate updates...
03-11-2025 12:19 PM
Ano, již jsem restartoval Chromecast audio po druhém dni, kdy bylo nefunkční. Už z důvodu toho, že v manuálu se doporučuje restartovat v případě chyby. Očekávám tedy aktualizaci a postup k vyřešení opravy. Děkuji
03-11-2025 12:20 PM
Les personnes vont se rabattre sur des produits chinois. Donc perte de part de marché. Dommage. Les produits Google sont très bon mais très chère. On s'attend plus de réactivité a ce prix. Surtout a l'heure de l' IA comment peut-on ne pas trouvé de solutions.
03-11-2025 12:19 PM
What happened if i alertdy factory reset the device?
03-11-2025 12:22 PM
FIX IT!
03-11-2025 12:23 PM
Following
03-11-2025 12:23 PM
asap, please
03-11-2025 12:24 PM
Looking forward to a swift solution!
03-11-2025 12:25 PM
Please tell us when a fix is expected.
03-11-2025 12:27 PM
My issue is connecting either my computer (mac) or ipad to my tv. It's worked flawlessly for years and suddenly a few days ago stopped working. I've tried resetting everything - including factory resetting the chromecast dongle - all to no avail.
03-11-2025 12:29 PM
Hi, have you found the solution?
03-11-2025 12:32 PM
Es gibt noch keine Lösung, wir müssen warten bis und ob Google wie versprochen ein Update sendet, fragt sich nur wie lange?;
03-11-2025 12:31 PM
I was in the process of systematically resetting all my google home devices since playing music stopped working. I just stopped before i factory resetted everything. Now, devices are still connected to wifi but unavailable in the google home app. Patiently waiting now for official instructions on how to fix.
03-11-2025 12:34 PM
Lo normal, al aparecer un problema de esta índole es reiniciar, vamos desde los inicios de la informática a sido un lema, antes de ponerte a llorar y patalear. No comprendo eso de que si ya se ha reiniciado es posible no poder volver usar el Chromecast. No estamos hablando de la Starship.
03-11-2025 12:33 PM
Chrome cast is not working. Every one is facing issue. Time wasted too to set up all possibilities. When it will be solve?
03-11-2025 12:35 PM
Can you confirm that this issue is also the root of scheduled announcements/broadcasts not being made through Google Nest speakers?
03-11-2025 12:35 PM
Authentication failed!
Google, what had you done??
Please fix it asap!
03-11-2025 12:36 PM
Has there been any updates on when this will be fixed? I performed a factory reset because when this issue first occurred on Sunday afternoon, one of the recommended steps is to reboot your streaming device
please post an update!!
03-11-2025 12:38 PM
That’s what they say not to do now.
Some Reddit users advice to change your phones date to the 8th and it will allow you to set up the Wi-Fi again in case you lost that due to the reset
03-11-2025 12:36 PM
Jetzt beeilt euch mal bitte, ihr habt die besten Software Entwickler der Welt und könnt so ein Bug nicht zeitnah fixen, dann seid ehrlich und sagt gibt kein Support mehr❗❗❗
03-11-2025 12:37 PM
Please fix this as soon as possible.
03-11-2025 12:38 PM
Any update on when the issue will be resolved? I was told I would get an email update, but haven't gotten any so far.
03-11-2025 12:38 PM
Please have i found a solution ??
03-11-2025 12:38 PM
OK you know the issue but when will you resolve it ? When your customers could use our device Google again ? Give more détails about delay
03-11-2025 12:40 PM
Hello, is there any update on the resolution of the problem? Even just a planning on it?
" Do not factory reset your device " well that was what most of us have done, trying to make it work, because there was no official statement from Google...
Hope you fix it soon and explain how to reconfigure it since I factory reset it...
03-11-2025 01:28 PM
Yo lo solucioné cambiando la fecha del móvil al 7 de marzo. Con esto consigues revertir el restablecimiento de fábrica pero el verdadero problema que es no poder enviar contenido. Así que no sé si tiene alguna ventaja…
03-11-2025 01:30 PM
Perdón me comí letras🤦♀️, esto NO soluciona el problema real, que es el envío de contenido
03-11-2025 12:41 PM
Please fix this.
03-11-2025 12:44 PM
When you'll fix it, please provide also instructions for whom that made factory reset.
Thank you
03-11-2025 12:45 PM - edited 03-11-2025 12:45 PM
Set date on mobile to before 9/3 and you will be able to reset.
03-11-2025 01:25 PM
Si riesco a collegarlo ma non funziona lo stesso per la trasmissione sulla tv
03-11-2025 12:42 PM
Deberíamos haber tenido conocimiento que ante una contingencia de estas con los dispositivos Crhomecast NO DEBIAMOS REESTABLECERLOS DE FABRICA , En mi caso tengo 3 de los cuales uno , el mas antiguo, dejo de funcionar y lo que hice ante la impotencia que sentí fue restaurarlo de fabrica , supongo que ahora le tocara a los de segunda y tercera generación. Se van a hacer cargo de mis dispositivos ? les sugiero que lo menos que podría hacer Google si fue esa Vtra intención , seria que entregando nuestros viejos dispositivos nos recambien por uno nuevo a mitad de su costo. Son demasiados costosos en mi País. Google siempre colaboramos contigo , por eso existes, pues bien , ahora veremos cual es tu limite.
