GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
All credits to tchebb from reddit
Workarounds
Although it's on Google to fix this issue properly, I've found a few workarounds that might get you up and running again, depending on the device you're trying to cast from. Note that I'm editing this comment frequently to refine the instructions and add new ones.
Fix casting from Android (GUI method)
  1. Download and install this Activity Manager app. I am not affiliated with it, but it's open source and seems to work as advertised. Note that you can download an APK directly from that page—you don't need to install F-Droid if you don't want to.
  2. Launch the app and select "Intent launcher" from the dropdown in the upper right.
  3. Tap the edit icon next to "Action" and paste in com.google.android.gms.cast.settings.CastSettingsCollapsingDebugAction. Leave all other fields blank. On Android 11 and below, use CastSettingsDebugAction instead of CastSettingsCollapsingDebugAction.
  4. Tap the checkmark in the lower right.
  5. In the settings panel that pops up, scroll down to "Connection" and enable "Bypass Device Auth".
This should fix casting from apps and partially fix the Google Home app. (It now shows me the Chromecast's status, but things like changing the name still don't work.)
Fix casting from Android (ADB method)
  1. Connect to your sender device (the phone or tablet you're casting from) using ADB.
  2. Run the following:
    adb shell am start-activity -a com.google.android.gms.cast.settings.CastSettingsCollapsingDebugAction
  3. In the settings panel that pops up, scroll down to "Connection" and enable "Bypass Device Auth".
As above, this should fix casting but not necessarily the Google Home app.
Fix casting from Chrome and other Chrome-derived browsers
  1. Download this file (which is just the CAs that have expired in PEM format), or copy the text into Notepad and save it as chromecast-ica-3-4.pem. [UPDATED March 11th to also include the Chromecast Audio intermediate. I changed the name from chromecast-ica-3.pem to indicate the difference. Big thanks to /u/meatbox for getting a copy of the Audio cert.]
  2. Launch Chrome with the command-line switch --cast-developer-certificate-path=chromecast-ica-3-4.pem by following the instructions for your OS here. On Windows, you might need to pass the full path to the downloaded file instead of just chromecast-ica-3-4.pem. (Thanks, /u/yossarian_vive!) For more detailed Windows instructions, see /u/FreeSpeech90's excellent reply.
Note that, while running with that switch, Chrome will show a notification stating "You are using an unsupported command-line flag". Seeing that is a good sign, but it doesn't necessarily mean you've specified the path properly. If casting still doesn't work, double-check the path and file name.
This adds the expired certificate as a root of trust, which bypasses expiration date checks.
i cant find "Intent launcher" in appen kun "IntentResolver", need help!
You'll Finde "Intent luncher" inside "activity manager app", an app inside f-droid
Agradeço a sua preocupação e atenção como merece, mas a minha paciência e a de quase todos está a esgotar-se, mas a minha preocupa-me e sou uma pessoa muito paciente, dê uma solução rápida ou aceite que não haja nenhuma, vamos organizar-nos e ver que fim daremos a tudo isto, isto está traduzido com o seu tradutor e espero que compreenda, a próxima mensagem será em chinês, japonês, aramaico e assim por diante até que compreenda, cumprimentos
Much better explanation of this issue on reddit here: https://www.reddit.com/r/Chromecast/s/Z4qr4tyaiF
Agradezo a túa preocupación e atención como se merece, pero a miña paciencia ea de case todos estose esgotando, pero a miña preocúpame e son unha persoa moi paciente, dea una solución rápida ou acepta que non a hai, organizarémonos y veremos que final lle damos a todo isto, isto está traducido co voso tradutor y espero que o entendades, a seguinte mensaxe sea en chinés e xaponés, saúdo ata que o entendades aramáico, xaponés.
Εκτιμώ την ανησυχία και την προσοχή σας όπως της αξίζει, αλλά η υπομονή μου και σχεδόν όλων εξαντλείται, αλλά η δικιά μου με ανησυχεί και είμαι πολύ υπομονετικός, δώστε μια γρήγορη λύση ή αποδεχτείτε ότι δεν υπάρχει, θα οργανωθούμε και θα δούμε τι τέλος θα δώσουμε σε όλα αυτά.
hi in in this issue and i reset my chomecast how can i fix it?
solo esperar ellos están trabajando esperar!!!
METTI DATA CELLULARE AL 7 MARZO
This information is too little, too late. Clearly you don't appreciate the impact this is having on your customers. But never mind, after 2 nights of not being able to watch any of my programs, I've had enough, and I've found a permanent workaround; My chromecast is going to e-waste and I've just finished setting up my new Amazon Fire Stick, which I think is a much better product anyway. I've also resolved to never again buy or use a Google product if there is an alternative available.
Seems befitting.  But this Tech companies of Trump era are so unethical, unreasonable and unreliable. Shame on Google
This is the error message i am getting across all my IOS Device.
Something went wrong
MyBedroom TV may be set up, but we could not communicate with it from your iPhone. Make sure that you have enabled local network access in your iPhone's privacy settings. Then try again.
On the other hand, for Android mobile
app Google Home Just Crashes.
How and when will we get notified if we had to go through hurdles just to find this out
What do we do if we've already tried to use a reset version of the device that the Chromecast is plugged into (in my case a TV) connecting with a third-party app? Do we get our previous version when the issue is patched?
Ok aguardo novedades gracias. No he podido configurar lo desde el 9 de marzo
I did reset it.
Me too, but got back to the previous phase by adjusting the date to march 7th on my tablet and then installing Chromecast again. I don’t know if this is to be recommended though.
I did a reset too but it's easy to reinstall.  Use any devices with Google home. Manually set your device clock to March 1 2025 or any date before March 9th.  This will allow you to reinstall your chromecast gen 2.
I've tried Google home, but it doesn't find my chromecast while it's plugged in and connected to HDMI.
Love it! Please work gard and fast. It's a great product!
  • Impatiently awaiting 1he fix.  Will finish some books in the meantime 🤷🏼‍♀️🤔
Thanks dears. Looking forward for your updates.
Your troubleshooting instructions TOLD US TO FACTORY RESTART the Chromecast device.  I would not have done so otherwise.
Please keep us in the loop
Will this be the best place to wait for an answer for the fix or know when the issue is resolved? I have 6 chromecast audios in canada brought in from Europe because they weren't available here and have a network of speakers through my entire property using them I will be very saddened if this is planned obsolescence and I can no longer continue to use them
Anonymous
Not applicable
The issue and the cause is already well understood and documented.  It has nothing to do with planned obsolescence!
Also maybe chuck a pop up com into the Google home app? Might save other users all this bother of having to search through support pages online and stop them factory resetting like it seem heaps of customers have done.
Anonymous
Not applicable
You honestly think it is as easy as 'chucking' a pop-up into an app?
  • I didn't factory reset my chromecast, but I did delete it from the Home app , and obviously I can't reinstall it now. At least I was able to warn my mom not to do anything with her chromecast (and explained what happened).  Please (please!) keep us updated and fix the problem as soon as you can.
I'd like to send your programmers a DVD player, so they can enjoy their media while they address this issue.
awaiting for the fix to this issue...
If we need to throw your product into the trash just let us know this is not acceptable to wait for days for a band-aide to your product.  If Google can't fix the problem just tell us your Gen 2 is for the landfill.
The only way my household can watch tv other then sitting on there phones is via chromecast.
We have 3 chromecasts not working. It’s been days and it’s more then frustrating!
Please fix this asap. I am still unable to connect Chromecast 2 device with WiFi network and it gives me error message as “Chromecast may be set up, but we could not communicate with it from your iPhone”
It's weird, first it showed that it was turned off somehow and I tried to reinstall it back in Home and now there's a pop-up stating that it couldn't authenticate the Chromecast. Geez, what now?
Anonymous
Not applicable
Wait till they have a fix!
Your own support page offers restoration as a solution. Now saying that devices should not be restored is borderline ridiculous. Resolve the issue soon. No to planned obsolescence of tech products.
Anonymous
Not applicable
And what part of this situation indicates it was 'planned'?  They had an expired authentication certificate on the devices!  People make mistakes, companies make mistakes.... they are working on a fix.  Enough with the planned obsolescence BS!
Anonymous
Not applicable
Repeating the same thing after 24 hours doesn't look like an update.. Ridiculous service,poor admin....
