GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,155 REPLIES 16,155
Please fix asap, don’t understand why it’s taking so long if it’s just an expired certificate, just update the expiration date. Not happy google.
Reddit… yeah, solid source, bro… that site is just a bunch of losers hopped up on crazy pills.
I bet you didn't even read the extensive information the person very kindly posted on reddit. And since you don't trust it or anyone for that matter, you can research yourself how a certificate works and deduce why the fix will take time. But I suppose being ignorant, rude and cowardly yelling from far away, is both not being a loser and really constructive for everyone 🤷🙄
If you don't want to understand or learn anything, that's your prerogative, but telling off another member for trying to be helpful is just wrong!
Screw you..mfk
Oh yiz.... I just did a factory reset
2025: AI, supercomputers and... FIRMWARE ISSUES. It´s a joke.
I would like to return my device now.
Too bad. Now buy a new one, goy!
Is there a way I can be notified instead of checking back constantly to see when this has been resolved?
I already did a factory reset too per your company's troubleshooting page. Very frustrated.
Ya yo lo reseteé de fabrica, me gustaría saber cómo actuar porque no quiere conectar ahora el tlf Android con el televisor, lo reconoce Pero finalmente no conecta. Espero su respuesta, gracias
Puedes volver a configurar cambiando la fecha del celular con el cual configuras y transmites contenidos al chromecast: cambia la fecha en tu celular al 7 de marzo, luego vuelves a realizar los pasos que normalmente harías para configurarlo, luego déjalo así nomas, hasta que los inoperantes responsables de todo este problema nos envíen nuevas instrucciones,  por lo pronto habrás logrado configurar tu chromcast y verás los lindos paisajes de Google home.
Aun así luego de hacer esto, chequea en la app de G. home la última actualización, sabrá Dios que nuevo parche habrán inventado tratando de arreglar el cagadon que hicieron.
I should have went with Apple TV from the get go, get stuffed GOOGLE.
As if that were a better option lol
Please advise when update is released
Is there an update for those that factory reset the device?
restore my all deta
How long will it take please to resolve the issue?
The issue will be resolved as soon as you fork up more cash and buy a new one.
I went and bought a Fire stick cuz I thought my chromecast was done for.
Exactly the reason why they made them all fail… so that we would all buy new ones…
So in the meantime what exactly ?? You need to start sending out replacements this is not fair to us as the consumer !!!!
Don’t be naive. This is obviously a scam to force you to buy a newer gen chromecast. “You should be sending out replacements” 🤣😂🥲 that’s cute.
Sorry, I didn't see the messenge and I already do the factory reset. What supposed to do?
トラブルシューティング中に出荷時設定にリセットしています。
従ってデバイスを再セットアップ出来ないでいます。
Obviously just a scam to force people to buy newer generation chromecasts that I’m sure are packed full of sophisticated spying capabilities. Wish google still held to the original “don’t be evil” principle. Sadly, those days are long gone. Goodbye American dream, hello dystopian nightmare…. Too bad that people tolerate this abuse….
Bye, bye.. Miss American Pie, drove my Chevy to the levee, but the levee was dry...
Yep. Totally agree. You can see my response. I'm on your side to the nth°
解りました。
解決策が見つかり次第連絡下さい。
よろしくお願いします!
I have 2 audios that have been offline for nearly a week. can you give us a timeline?
Hola. Lamentablemente restauré de fábrica el dispositivo y no puedo reconfigurarlo. Por favor necesito ayuda. Gracias
After so much head-hunting, I found this community note.
Waiting for the fix asap.
Anonymous
Not applicable
please update us
I did a factory reset..now it's not gonna work anymore?
Been waiting 3 days for my Chromecast to work.
So is this a ploy to get us to purchase the latest version of? Because I’m in no position financially to buy a replacement.
I really wish Google had informed us ahead of time that this was happening, instead of locking us out with no warning. Makes me think twice about ever  using any Google products or platforms again.
I would appreciate an email whenever you make that fix: #
Thanks
suz4
The net says everyone would get an e mail about it I haven't got one. I also can't afford to buy something else
How long it will take to fix the issue of the chromecast????
