Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-11-2025 10:05 AM
Espero que Google no haga lo mismo que hizo con los Google home primeros que se los cargó
03-11-2025 10:15 AM
Isso tb aconteceu comigo, a 2 dias não consigo conectar nada e qdo tento vem uma mensagem que o firewall está desatualizado.
03-11-2025 10:16 AM
Tengo el mismo problema de autentificación y también me paso asi de la nada
03-11-2025 10:23 AM
Ha 2 dias atrás, meu google chomecast desconectou sozinho, reiniciei e depois como nao voltou, resetei e comecei a reinstalar, aparece a numeraçao mas quando chega o momento de configurar vem a informaçao que nao e possivel autenticar o dispositivo e manda contactar o suport.google.com/chromecast.
03-11-2025 10:23 AM
Same issue here and we wait for Google to respond with a fix I suppose.
03-11-2025 11:02 AM
Same problem
The setup is interrupted with the message that my chromecast which worked perfectly until march 8 2025 is no longer authenticated
03-11-2025 11:03 AM
Yo tambien tengo el misma problema con mi chromecast
03-11-2025 12:14 PM
Exatamente a mesma data que começou a aparecer esse bug no meu 08 de março de 2025.
03-11-2025 01:33 PM
I've had the same problem since yesterday.
03-11-2025 02:48 PM
ME TOO
03-11-2025 04:15 PM
Same problem amateur hour for Google looks like we will have to move to Apple if Google doesn't fix the most simple problem.
03-11-2025 08:13 AM
Dear Team,
Chrome cast not getting connected...error showing as ' we couldn't authenticate your Chromecast...support google'
Please check and help me to resolve the error...
03-11-2025 07:47 AM
Like everyone else I am experiencing problems and am currently unable to cast from my phone/tablet.
Unfortunately i have already tried to do a full reset as I was not aware that this was inadvisable.
I'm aware that Google are currently trying to fix the problem and wondered whether there was any way to create an alert to advise me when the fix is launched so that I can try to get back to casting?
03-11-2025 09:14 AM
I'm in the same boat as you. Did you get to the page where it trys to connect to wifi and then eventually goes back to the get the app page?
03-11-2025 10:58 AM
If you factory reset you can get your chromecast back on Google home by setting your phone/tablet date to a date before march 9th then once it's in set it back to actual date. You still can't cast anything before they come with a fix but at least you can see the Chromecast again while waiting for the fix to be sent out from google
03-11-2025 07:25 AM
My Chromecast stopped working Sunday evening 🥺😔😔😔 I'm going crazy I'm good at technology but nothing worked
I even uninstalled my Home Google but NOTHING WORKED! CAN SOMEONE TELL DO I NEED TO BUY ANOTHER ONE?
I used this for years of not a decade
03-11-2025 07:44 AM
This post is pinned to the top of the Streaming section of this site:
It explains that Google is aware of the issue and are working on a fix. In the meantime, do not factory reset if you haven't already, at there may be extra steps to go through when they do get a fix.
I'm going just as crazy as you are, hang in there.
03-11-2025 07:58 AM
Igual, yo salí de viaje de trabajo y hoy martes, que quiero disfrutar de Chromecast, me encuentro con la sorpresa, de que mi dispositivo no se puede verificar, no cabe duda, cada que actualizan algo, en lugar de mejorar, mandan todo ala mier@#$$, espero que nunca Google saque, robots autónomos, para ayuda del ser humano, porque de otra forma, todas esas películas que hemos visto se van a volver, mera realidad
03-11-2025 07:26 PM
I appreciate your concern and attention as it deserves, but my patience and that of almost everyone is running out, but mine worries me and I am a very patient person, give a quick solution or accept that there is none, we will organize and see what end we give to all this, this is translated with your translator and I hope you understand it, the next message will be in Chinese, Japanese, Aramaic and so on until you understand it, greetings
03-11-2025 05:59 AM
Any updates with the issue with the chromecast? It has been 2 days without been able to use its.
Thanks.
03-11-2025 06:41 AM
O meu também está assim a 2 dias!
03-11-2025 08:00 AM
estoy en la misma. nadie dice nada. problema a nivel mundial
03-11-2025 05:56 AM
When i try to connect to chromecast I get a pop up that says Connect to device failed. Failed to connect to selected device. Please try again later. How do u fix it?
03-11-2025 07:28 PM
03-11-2025 05:52 AM
Het lukt niet om uw Chromecast te verifiëren. Kunt u mij helpen wat er aan de hand is?
03-11-2025 06:02 AM
Dat is bij ons al 3 dagen zo, Google zegt er mee bezig te zijn maar het heeft klaarblijkelijk geen prioriteit....zelf heb ik net mijn laptop met een hdmi kabel aan de tv gehangen zodat we wel iets kunnen kijken via NPO start of bijv Netflix. We wachten het verloop maar rustig af denk ik.....
03-11-2025 06:47 AM
Hier ook problemen met verifiëren.
Het enige wat je kan doen is een klacht sturen en hopen dat het snel verholpen wordt.
03-11-2025 07:29 PM
In the meantime new generation of google chromecasts are sold, excellent move Google. Not buying google products with programmed obsolescence anymore.
03-11-2025 05:48 AM
My Chromecast didn't update latest firmware
03-11-2025 05:41 AM
I’ve used this device for years. It stopped working recently. I tried basic troubleshooting, reset the device and tried to add it back.Everything goes well, including appearing to connect to local wifi. And then it fails. I get a connected image, but the message, something went wrong Condo speaker may be set up, but we could not communicate with it from your iPad. Make sure that you have enabled local network access in your iPad’s privacy settings. Then try again.
Any thoughts greatly appreciated. Thanks.
03-11-2025 05:46 AM - edited 03-11-2025 05:48 AM
Hi I have been having the exact same issue. There is a system wide issue that has impacted many users. They told me that they are working on fixing the problem. They said not to factory reset but that was one of the first things I had done based on their suggested steps. Hopefully they will be able to figure out the issue soon! Mine has been down since Sunday
03-11-2025 06:00 AM
Thanks. Mine has been down since Sunday as well. I actually thought about getting a new one but I will wait to see what happens. I did factory reset mine but it did no good. Back to the same place.
03-11-2025 05:32 AM
I've reset my Chromecast by addin' it back to the Home app, I have set my cellphone to March, 7th and then started the procedure to connect it to the home Wifi, now it's back on my TV and on the Wifi, I think that's better when Google fixes this.
Don't forget to put your cellphone back to the correct date and time.
03-11-2025 05:57 AM
Still waiting, I just tried to cast, but nothing yet.
03-11-2025 06:21 AM
Je viens de mettre mon téléphone portable sur le 3 mars. J'ai réussi à reconnecter mon chromecast. Mais rien ne fonctionne dessus. Impossible de caster la tv... que faut-il faire d'autre ? Merci.
03-11-2025 05:15 AM
De repente el Chromecast ha dejado de funcionar.Yo he reiniciado el dispositivo y ahora el sistema a través de Google home me señala que el dispositivo no se puede autenticar. Me pueden decir cómo volver a restablecerlo?
03-11-2025 05:43 AM
no hagas nada estamos a la esbera de big G que lo solucione
03-11-2025 01:07 PM
Ya llevan 2 días…
03-11-2025 03:51 PM
Será que foi pane geral , o meu tá assim a dois dias
03-11-2025 06:25 AM
Chrome cast not connected to wifi
