Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-12-2025 07:16 AM
I have same issue also
03-12-2025 11:03 AM
Same problem, my chromecast doesn't work since yesterday. I have reseted to factory values, but now it doesn't abe to autenticate.
03-12-2025 12:48 PM
The only way to get it connected again is to roll the date back on your phone to January and connect and set up the device. This will get it connected to the internet the rest is up to Google getting a fix. Remember to fix your date as nothing else will work until you do.
03-12-2025 06:30 AM
???????? WTF ??????????????
03-12-2025 06:54 AM
No mundo inteiro pessoas perdendo dinheiro investido ppr que a porcaria fo google resolveu a trancar todos os chromecast. E um absurdo. E nem uma resposta aos clientes eles dao. E apebas enrolação da pior qualidade. Ja sao 3 dias! Dessa palhaçada!
03-12-2025 07:20 AM
03-11-2025 09:47 PM
For 2 days it can no longer be configured, will I go?
03-11-2025 10:45 PM
There is a problem world wide with the gen 2, I did all the trouble shooting like the help says. Then logged a call snd sent messenger message teand then sent messenger message. We got the following reply 2 days ago "Hey there, we're aware of an emerging issue impacting Chromecast 2nd gen and Chromecast Audio devices and are working on a fix. Do not factory reset your device - we will keep you all updated when the fix rolls out. If you have already factory reset your device, we will provide instructions to set your device back up as soon as possible. Thank you for your patience." Nothing since
03-11-2025 11:16 PM
03-12-2025 06:17 AM
n'avons plus de télé à cause de ce chromcast qui ne veut pas s'authentifier
03-12-2025 07:20 AM
03-12-2025 12:22 PM
Today is Wednesday and still no fix.......
A good idea is to inform your user base about progress of the fix ....
03-12-2025 12:26 PM
Despues de 3 dias los que reiniciamos seguimos sin soluciones.
03-12-2025 12:27 PM
How are we on day 3 without a fix globally?
03-12-2025 12:31 PM
Your stupid tech support team told me to do a factory reset. Now what genius?
03-12-2025 12:31 PM
YOU DO REALIZE THAT EVERYBODY HAS ALREADY DONE A RESET
03-12-2025 12:31 PM
Please fix it asap. I need instructions for the procedure after factory reset too
03-12-2025 12:35 PM
I reset during the troubleshooting, do you have a date when it will work again?
03-12-2025 12:35 PM
I have allready Done factory reset. Is my device now worhless???!!!
03-12-2025 12:38 PM
I'm currently facing this issue—thank you for your efforts in resolving it! I'm really looking forward to having it up and running again soon.
03-12-2025 12:54 PM
Article about the issue: https://www.aftvnews.com/googles-decision-to-lock-down-google-casting-has-bricked-older-chromecasts/
03-12-2025 01:18 PM
They didn’t even dare understand the issue . It’s just the CC internal SSL certificate that expired . That article is pure BS!
03-12-2025 12:39 PM
Nothing is working. I cannot cast to any of my devices of which I have about 30. Doesn't matter how old they are. I can view the camera on my nest Max home hub, but I cannot control anything else on it. It won't even let me look at the settings. Same goes for all my other devices. Chromecast audios speakers Google homes nest homes so on and so forth. Nothing works. Unfortunately this happens all too often.
03-12-2025 12:46 PM
I reset the chromecast 2 nd generation... what can i do to configure again? I want a reply
03-12-2025 05:20 AM
Sigo sin poder configurar el Chromecast. Desde el domingo 09/03/2025 que no me funciona (en 7 años jamás dejó de funcionar)
Acabo de actualizar la app Google Home a la version 3.30.1.5 y aún no me permite configurar el dispositivo.
Aguardo respuesta
03-12-2025 05:22 AM
Hello, I also restored it to factory settings and following the following steps I was able to reconfigure it, I managed to broadcast from the mobile to the TV again, but the image from the mobile is only partially displayed, at least I was able to reconfigure it and now I just have to wait for the update.
First of all, you need to change the date on your mobile phone to a day before March 9, 2025. From here you can reconfigure the Chromecast.
Then follow the following steps to be able to broadcast again
This workaround forces open the Cast Debug settings page and lets you enable the Bypass Device Auth option (i.e., it allows you to turn off device authentication), partially fixing the issue. You should now be able to cast from apps, and the Google Home app should also partially work.
03-12-2025 05:24 AM
Hola, yo tengo exactamente el mismo problema. De pronto dejo de funcionar y ahora no puedo volver a configurarlo.
03-12-2025 05:31 AM
Lo mismo me pasa a mí. No se puede autentificar el Chromecast.ya sin muchos días esperando para una solución .
03-12-2025 12:47 PM
Unfortunately reset was done already beacuse most of time only that work , issue started with not able to cast due to outdated firmware warning not its gettimg setup and says cant communicate to chromecast
03-12-2025 12:46 PM
Send out updates! I had to hunt to find out there was stupid problem!
03-12-2025 12:49 PM
Har allerede tilbakestilt den.
03-12-2025 12:49 PM
Non riesco a connettere il mio dispositivo al cromcast
03-12-2025 05:47 AM
My Chromecast is not being authenticating
03-12-2025 05:51 AM
Pareil pour moi depuis dimanche à 18h...
03-12-2025 06:11 AM
Same here since a couple of days...
03-12-2025 07:03 AM
Same here! What is happening?
03-12-2025 07:21 AM
03-12-2025 07:32 AM
Same here for the past 2days
03-12-2025 12:53 PM
Will that be fix at all? I spent 3 days and 2 phones (android and iPhone) and tones of different apps to figure out what's going on. You should have better way of letting ppl know that problem is on your side. Had no clue about this website. Waisted 3 days and now know one can give us an ultimate time when problem will be resolved.
03-12-2025 04:33 AM
My Chromecast IS not working .Authentification failled.I Have reset wifi and Chromecast and still not working .This has happened to my 3 devices. At the same time .
