GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,159 REPLIES 16,159
Tengo el mismo problema que tú. Espero nos puedan ayudar a solucionarlo
Same issue in Wilde, AV.
Mismo error.
Mi version actual de firmware:
Versión de firmware del sistema : 275994.
Firmware de Cast : 1.56.275994.
Segun this link
La version actual en produccion es para los Chromecast 2Gen es 1.56.275994. La que todos tenemos y aun asi no funciona.
Same hire...R.I.P. chromcast5420
Hi I've seen I am not the only one having this problem I have seen its a problem for a lot of people where I cannot use my chrome cast I've never had this problem before try to reconnecting it but says it can't I've tried everything can't seem to get it to work
Starting tonight my chromecast just stopped working. It worked earlier today then suddenly no.. and after doing everything i'm supposed to do with restarting and resetting things it keeps failing the authentication process... and it seems other people are having the same issue? Any ideas?
Same.
Desde MVD, UY. Lo mismo con ambos Chromecast en casa.
Same error
Two gen2 devices in Costa Rica
Yes. I am getting the same pop up message on my chromecast just now in the Netherlands
Hi I am having the same problem I've tried everything 🤔
Dispositivo non attendibile. Impossibile verificare Chromecast. Ciò potrebbe essere causato da un firmware del dispositivo obsoleto.
Ho eseguito un ripristino delle impostazioni di fabbrica e ora ottengo:
Non siamo riusciti ad autenticare il tuo Chromecast. Visita support.google.com/chromecast per ricevere assistenza nella risoluzione di questo problema.
Dispositivo: Chromecast 2a generazione
Regione: Italia
This appears to be a large scale issue with Chromecast devices no longer being authenticated by Google. Hopefully this is a daylight savings time sync or other quickly addressable issue. Other users are reporting similar problems on Reddit.
https://www.reddit.com/r/Chromecast/comments/1j7c352/chromecast_is_untrusted/
Anche in Italia chromecast non funzione e non viene riconosciuto al momento dell'autenticazione
Having the same problem. This is **bleep**ed google
Aqui tbm estamos na msm situação, não configura novamente. Brasil
Same here now. Only one is showing up. Our home one is no longer working despite multiple reboots/resets.
Desde Uruguay, el mismo problema. Alguna solución?
I am having the same issue. I have tried a factory reset on the Chromecast device and now I am unable to complete the setup. Very annoying.
There is something oddly beautiful in the connection through lack of connectivity.      As frustrating as this is, we can see we are not alone, which is something we tend to forget as we encapsulate ourselves in our bubbles of entertainment.
     Now, if we could maintain such connection when the distractions are returned to our immediate environments, that could benefit all of us.
Same issue
Same issue "cannot authenticate Chromecast Audio" from Italy, model rux j42
I was just watching it. Went to the store and came back now it's not working. Restarted and reset everything multiple times and still nothing.
Same.  I was literally using my Chromecast Audio this morning to stream Spotify.
I know they ended the product in 2019 and said they'd keep releasing updates until September 2025 but it looks like a TLS security certificate on the device finally expired and they didn't update it to a new one.  Unless Google is willing to update the certificate it's trash now... unless Google helps us transition it to the OpenSource community and maintain it ourselves. What a waste.
Our was working this morning and then stopped.  I have reset both our phones, factory reset the Chromecast and my wifi router as well. I even deleted my Chromecast and tried to set up the device again to geth the couldn't authenticate your device message.
Same problem here. I have two NC26A5 and both stoped to connect with my Iphone or Android. "outdated firmware". - from Brazil
Same here, can't suddenly cast on chromecast audio.
Sama dgn saya, from Indonesia
Hallo zusammen, seit heute abend funktioniert mein chromecast nicht mehr heute morgen lief es noch einwandfrei. Trotz auf Werkseinstellung zurückgestellt kommt immer wieder dieselbe Meldung lässt sich nicht authentifizieren. Ich bitte um eine Erklärung und Abhilfe. Vielen vielen Dank im voraus. Beste Grüße
JA É NOTÓRIO QUE HOUVE UMA ATUALIZAÇÃO DE FIRMWARE E GEROU ESSE PROBLEMA NO DOMINGO , POIS NÃO TEMOS SUPORTE ( BR ) E TAMBÉM RELATADO NA FRANÇA , ESPANHA, PORTUGAL , ARGENTINA E VARIOS OUTROS PAISES ...
O FATO: ESTAMOS SEM CHROMECAST...
O QUE FAZER...
AGUARDAR OS TÉCNICOS RESOLVER O ERRO ...
VAMOS AO X E TODAS AS REDES SOCIAIS EXPLICAR ISSO APARA TODOS OS OUTROS CLIENTES OU. USUÁRIOS
My iPad and iPhone apps suddenly stopped casting while watching a video. Chromcast is working displaying its public photos, temp and clock but non of the apps are casting. YouTube given me outdated device firmware error when it tries  to connect.
i switched off/on the iPad,  chromcast  and the router
i tried customer service but their agent didn’t seem to have the expertise
same issue with my chromecast audio. was using it earlier today, then it showed as offline and i couldn't cast to it. I tried to reset it but now i can't connect, i get an error that 'We couldn't authenticate your chromecast'. the Home Mini that i have still works fine. i tied resetting, clearing cache and storage on the Home app, restarting, multiple times. I do notice that the options when adding a new device in Google Home app look different, only 2 options instead of 3. COuld be a Home app update that went wrong?
Same here in Spain.
Same here in Sweden on three ChromeCasts at the same time...
Andrea from Italy, the same here.
Chromecast second gen stopped working (wifi connection ok but no cast and missing access to my Google account).
I tried reset and now it won't activate anymore, authentication issue.
Google killed old devices on purpose, it seems.
Same problem. Restarted wifi and tried to reinstall my 4 chromecast units. Didn't resolve anything.
Same issue
Same here. Old circular puck Chromecast version.
Stesso problema. Se avessi letto prima il forum non avrei sprecato 30 minuti per fare prove di restart e reset.
Attendiamo soluzione.
Anonymous
Not applicable
El mismo problema no se puede autenticar tu chromecast...
Google HOLA?
