GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,146 REPLIES 16,146
All of sudden unable cast and it's giving error like could not framework some thing like.
I tried to reset chrome cast but it's giving  we could not authenticate your chrome cast. Please suggest on this
Hello Google!  Congrats! You just killed millions of Chromecasts with a wrong certificate. Ask Gemini on how to undo.
Estan borrando los hilos de convercacion con este tema
I’m having the exact same issue, been trying to sort it for 35 minutes, nothing will work. it was working absolutely amazing up until today what has happened?
Me párese un error que Dise, autenticador de chromecast
Chromecast worked fine 4 hrs ago.  Now I press the cast symbol, it goes to the options of where to cast and then nothing happens.
I just hope Google will fix this issue ASAP.. or at least decent announcement if they want to kill old devices.
Sinds vandaag wil mijn chromecast niet meer streamen, wat is er aan de hand??
Lo stesso è sucesso a me e nel resettare il Chromencast per riconfigurarlo da capo mi da il segiìuente errore "impossibile autenticare il dispositivo Chromecast". Vedo il codice sulla tv ma non compare sul cellulare e quindi non riesco ad autenticarlo. Conclusione, all'improviso niente Chromecast !!!!
Aconteceu o mesmo comigo. Reiniciei o Chromecast e agora quando vou reconfigurar aparece a mensagem dizendo que não é possível autenticar. Já tentei de tudo e não consegui arrumar.
Several chromecast sticks (all of them gen 2) have the same Issue. As I tried with one of them to make a complete reset, this chromecast stick cannot be re-installed into my Google home App. Quite sure there is an major issue within authorisation for gen2 devices which are not related to specific accounts but all over the world... hopefully google will fix this soon. Thanks.
My iPad and iPhone apps suddenly stopped casting while streaming (watching)  a video. Chromcast is working displaying its public photos, temp and clock but non of the apps are casting. YouTube given me outdated device firmware error when it tries  to connect.
i switched off/on the iPad,  chromcast  and the router
i tried customer service but their agent didn’t seem to have the expertise
My Google chrome cast stopped working
The one i mentioned in my post was actually 3rd gen so i guess all chromecast got impacted
7 Chromecast Audio devices show offline in my Home app. I have a couple Nest Mini devices that seem to be working fine. I did not see any errors related to 'untrusted' Chromecast devices when I tried to reconnect my Ccast Audios, but it makes sense. I think I saw the Chromecast Audio device appear in the Home app briefly, before going offline again. Maybe there's a log file in the Home app?
I have an Android phone, but I noticed the Google Home iPad app is not loading any devices right now. I have a few smart bulbs along with Chromecast Audio, and Nest devices in the Home app. On my Android phone, everything but Ccast Audio loads, but on iPad nothing is loading. I restarted the iPad and have waited many minutes, but nothing will connect on the iPad. It worked fine on Friday. Maybe unrelated, but frustrating.
I know we're on borrowed time with Chromecast Audio, but I hope this isn't how we find out these devices a bricks. It's so disappointing that Google stopped making Chromecast Audio. Cheap, reliable, and solid audio streaming. It's the ideal solution for me, and I hate the thought transitioning to some other audio streaming platform.
#me2
Tryied reset and now cant even configure or conecnet to wifi
Doing some research found a post on Reddit, appears to be a widespread issue affecting all gen 2 chromecasts. They better find a fix...
What is going on!!!! My Cromcast is not casting to my TV!!!
Same problem here in Spain.
Simplesmente do nada o meu dispositivo para de se conectar, o google home diz que ele esta off-line enquanto ele está ligado e funcionando na minha tv e não consigo colocar nenhum vídeo para tocar nele, fiz de tudo, até reiniciei e agora o google home diz que não consegue autentificar e me manda para a ajuda, porem a ajuda é completamente inútil.
Local: Brasil
Chromecast V2 (provavelmente)
Estou a tempo tentando resolver o problema do Chromecast que parou de funcionar e agora descubro que foi geral e não só comigo. E aí dona Google?
Ich habe da gleiche Probleme min. 4 Stunden. Chromecast ist in Google Home nicht mehr verfügbar. Reset funktioniert chromecast wird auch gefunden im WLAN aber Einrichtung. scheitert dann. Der Code wird mir auf dem TV angezeigt aber nicht auf dem device. Verschiedene devices verwendet! Chromecast 2 Generation
Same, I have multiple Chromecasts that just stopped working today.  They are still not working after trying a reboot and reinstall.. Just getting a message that they cannot authentication the Chromecast
Sme problem here. Have been trying to connect to Chromecast for past 3 hours and keep getting error message 'We can't authenticate...'. Have factory reset and rebooted a number of times and same message comes up.
Same here in Uk
Same exact issue here with Chromecast Audio. I've been using this wonderpuck daily for 10 years, what an absolute farce that a device that functions perfectly can just be "switched off" with no warning and turned into useless plastic.
Hello
Même problème ici en France depuis cet après-midi
Same, just adding incase weight of replies means something 😬
I had the same...after some f ing around for 2 hours it now says cannot authenticate !!! Grrrrrrr
Mine did the same thing while I was watching it today
Estoy con el mismo problema
Same issue here
Same here. Outdated firmware.
Same here. Firmware version 1.56.275994
Same here in Norway.
Gen2 chromecast, after reset i get a fault saying it failed to authenticate.
same problem here. i'm from Italy.
I did factory reset. Now, when i try reconnect to my google Home i have the message: We couldn't authenticate your Chromecast. Please visit support.google.com/chromecast for help troubleshooting this issue.
Can't add anymore my device and i can try anything
Same here. My Chromecast stopped working. I factory reset it. Try to add to Home app on Android: could not authenticate. Home app detects it, but cannot authenticate. I tried to connect to Chromecast's wifi, Home app just freezes out
Same here in Poland, tried everything and nothing worked. All was fine today until around 16:30
Same here!
