GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,145 REPLIES 16,145
Same here
Google team please resolve ASAP
Same problem here I reset it and now couldn’t connect to again
any possible solution??
Same here, Hope we get a response soon
hello,
I'm just wondering if the issue/error mentioned is fixed? My device is having the said issue still.
Same issue in UK. All my Chrome cast devices have stopped working.
Same here, from Indonesia. 😓😭
J'ai acheté un Mi TV Stick (FHD) et ça fonctionne. Mon problème est réglé.
xactly the same here in UK, pretty shoddy if you ask me, any updates from Google itself, or is that too much to hope for?
Canada. Gen2. Won’t connect even after factory reset
my second generation Chromecast was dead as well, from Spain
Same here. 🇸🇪
Ours also happened, same time frame. Hoping to follow this for a fix!
Same here.🇸🇪
The issue is that your CC devices all have a signed certificate with 2 CA which one of them is an intermediary one with a validity from March 9th 2015 to March 9th 2025 ... Google will need to provide a firmware update with renewed certificates or provide the same certificates to all CC devices .  I'm not sure what else they can do given the certificate expired and it's needed to insure the signed certificate (the CC device cert itself) is valid.   I can't say it was definitely planned like that , I think it's mostly something people overlook and create production downtime .
Same here, stopped working yesterday
I cannot post the link but there's a post on Reddit on the r/Chromecast page
Global issue.
Having the same issue. Started a Factory Reset, and when I try the set up, I get the "Failed to Authenticate" notice with navigation to the Troubleshoot option for a resolution which is no help what so ever.
Wonder when this will be resolved and if we'll recieve some form of compensation for the inconvenience caused. 🤔
Hola, mí Chromecast 2, no funciona. Alguien sabe si Google corrió este problema? Gracias.
Me pasa lo mismo desde ayer.
You're all drowning the information contained in the posts of this forum with "I'm affected as well" when the post just before is stating:
An intermediary SSL Certificate expired on you CC device.  Google needs to either renew that certificate and resign all CC SSL certificates with the new intermediary SSL Certificate or come up with another solution that would be quicker to deploy on those millions of devices.
If you factory resetted your CC, just set the date of your phone to March 7th 2025 and add it back so it can communicate with the CC update server when a fix is available.
Well this is the response from Google that I received:
Hi There! Thank you for reaching out.
Thank you for the information, and we appreciate the troubleshooting steps that you already tried.
We wanted to let you know that we're currently experiencing some issues with Chromecast devices. Our team is on it and working hard to get things back to normal ASAP!
We know this can be super frustrating, and we're really sorry for any inconvenience this might be causing you. 🙏
Thank you so much for your patience and understanding! We'll keep you updated with any progress. In the meantime, if you have any questions or need help, drop us a message!
 Unable to authenticate error / firmware error when trying to reboot and or connect to device from HOME app
Same issue in Argentina
I really hope this is not the end of my Chromecast Audios.  I have 2 I use(d) every day, another occasionally, and used multi room with these along with my Home Max and Home devices.
If this is the end of CCAs, are there any recommendations of similar devices that support the Google Home platform and will allow casting audio to device groups?
Se sabe cuanto puede demorar una solución????
So, is this happening all over the world, yet google didn’t confirm anything. Hello… It’s been 2 days…
I have the same issue. Since yesterday four of our chromecast devices stopped working.
Google please update asap
Same.
Just came home from work yest and device has stopped working.
Same problem as everyone here.
Any updates on this issue pls? Still unable to connect
Mismo problema desde Buenos Aires, Argentina. Espero que den noticias cuando lo van a solucionar y cuando lo solucionen
Same here, exactly at march 10, 00.05 am. I have the same issue. Whats should we do
Such critical information should have been tested before mass deployment. impacting at global level without prior information is not good .. It would be good if google give some resolution timelines.. it is super frustrating
Same issue with chromecast audio, all 3 pucks in use in my Chicago area home.  Please fix!
I'm having the same issue, please fix it Google!
I’m having the same issues
Called Google and apparently working on the glitch If you wait 24 to 48 hrs and retry, they say the issue will be fixed
Same issue with me in New Hampshire. WTF!
If anyone gets solution to this problem and able to restart chrome cast streaming, kindly let us know, thanks
