GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,146 REPLIES 16,146
No, no pude.
Todos los, chromecast dejaron de funcionar que pasa google reparen este problema rapido.
careban01
No solucionaron nada! Estoy en Argentina, la hora local es 02:10
Rene11
Es una muy mala accion de google, decir ahora que no restablescas el chromecast, por que no podras solucionar el problema, si el problema se dio el dia de ayer en mi caso y nadie de soporte te asistio, muy mal google
Did a factory reset of the Chromecast and when I tried to re-connect via the Home app I got the message "We couldn't authenticate your Chromecast."
  • Chromecast 2nd gen
  • Pixel 6a
  • Android version: 15
  • Android Security Update: March 5, 2025
  • Google Play System Update: January 1, 2025
Edrizio
Então esse que temos não serve mais ?
Rene11
Ahora google dice que no restablescas el chromecast, muy mal por parte de google, el problema es global.
No puedo establecer conección de Chromecast me pedía actualizar, lo resetie pero no jala. Sale un mensaje que dice que no se puede autenticar tu Chromecast. Ayuda
Me pasas lo mismo desde hoy que estoy intentando y me aparece ese msj
Muitos usuários estão reportando o mesmo, acredito que foi geral, aguardando uma solução
Happening in TN, USA. Same thing. Tried all the fixes and then factory reset it. "Can't authenticate Chromecast."
It is happening in Brazil, Argentina, Spain and USA, so far that I was able to noticed.
Peru as well.
User tchebb on Reddit broke the issue down in a very comprehensive way.
(TLDR: Certificate expired. Not much for us to do, except wait for Google to fix the core issue. There are some workarounds provided in the Reddit thread though!)
https://www.reddit.com/r/Chromecast/comments/1j7lhrs/the_chromecast_2s_device_authentication/
DebWilly
Very technical breakdown of the problem.
Seems that Google need to change a certificate for 2nd generation chromecast devices. Great explanation and breakdown.
Now Google should be able to resolve the problem!!
Holy smokes, the fixes in that thread are to die for. Wish I had the ability to soak it up and safely do it lol. Definitely NOT in my wheelhouse, but what a great read! Thanks for the heads up on that though! I did post a stand alone 'issue' here, instead of just my initial reply earlier, with the information that I had gathered-stating that it indeed seemed as though it was a coding issue or an AI glitch, lent heavy on the coding glitch though, since the permissions were dimmed out. Such an odd thing though. You'd think you could at least hook up to WiFi, but just not stream since-however that would be even more frustrating to me, imo. hagn, thanks again!
My chromecast stopped working yesterday afternoon, about four o'clock. And it's still not working. The Netherlands. Did Google punish me for watching porn on saturdaynight?😗😚
Wendyf
Same here, accept the porn 🤣
Bas3
Hoi Wendy, je bent best technisch hè?
Hier is de oplossing, deels in Nederlands:
https://www.googlenestcommunity.com/t5/Streaming/Hoe-je-de-ChromeCast-2e-Editie-weer-werkend-krijgt/...
Groetjes Bas
I have the same problem with 2 chromecast and am in Australia..  No clue how to actually fix the problem..
Steve_D
search "Google Chromecast Outage"
its global.  news headlines all over
Tonyk67
Google's second-generation Chromecast and its Chromecast Audio are suffering a major ongoing outage, with devices failing to cast due to an expired security certificate. The web giant is aware of the breakdown and says a fix is in the works.
On Sunday, many users of these gadgets encountered an "untrusted device" error, preventing them from casting content to TVs and other displays. Tech-savvy netizens quickly traced the issue to an expired intermediate certificate authority – created by Google to handle authentication for the affected equipment – which lapsed on March 9, 2025, at 1644 UTC after 10 years of validity. Models relying on this authority no longer work as expected due to this expiry; they can't securely connect to Google's backend systems and authenticate themselves.
"We're aware of an emerging issue impacting Chromecast 2nd gen and Chromecast Audio devices, and we are working on a fix," Google told The Register on Monday.
In an update on the Google Nest community site, where Chromecast support seems to live these days, the internet titan added, "Do not factory reset your device - we will keep you all updated when the fix rolls out. If you have already factory reset your device, we will provide instructions to set your device back up as soon as possible."
Same with my Chromecast in the Netherlands, did everything to reconnect but noting worked. Hope Google will fix this problem soon.
I read that it's global Google doesn't support the Chromecast 1 and 2, they want us to buy Google TV, if this is true I will never buy any product of them. Then Apple will be my middlename.
My chromecast gen1 is still working fine, only problem with my gen2
I have tried factory reset but not I am not to connect to cast device with authentication error. How I should resolve this any steps which will help here
No way. It's a problem that only Google can resolve with an upgrade. But the question is (I've reset to fabric too one of my 2 devices): a reset device will be configurable in some way to get the update?
Yes , just set the date on your phone to March 7th 2025 and add it back.
The same happened,  I tried to do everything, factory reset etc multiple time, but I am unable to even connect with chromecast after reset with the 4 digit code from TV as it's not appearing even after 20 efforts
You don't need to factory reset multiple times...just one is enough! 😉
We reset multiple times because the one time did not work.
I saw the same topics in 2023 and the problem is still here.
- Do you want to configure Chromecast1633?
- Yes
- Connecting... No, authentication failed, please proceed to the article that can't help with your problem.
So frustrating and disappointing.
Me pasa lo mismo. Soy de Argentina.
Samme problem sidder, jem med nu.
Hds
Same here in France...
Today, all my chromecast audio were offline! Resetted all devices (factory reset). Tried to add them back with google home. It says they are untrasted device, I m not able to have my  any chromecast audio back to my google home!
I think it is happened after an update. Google please...don't do update. You are not able anymore to do a good company! Please just don't do nothing...
byeager
I'm in the same boat. My nest devices are working fine, it's just the Chromecast devices that will not connect. What is going on with this?
Same here,  chromecast switched off halfway through a program and can't setup now.  Sort it out Google please
Me too. 5 chromecast audio devices working fine earlier today and now not at all.
Anonymous
Not applicable
Chromecast no me dejaba hacer streaming y después de resetearlo no se puede configurar y añadir a Google home. Me dice que no se ha podido autentificar mi Chromecast y que acuda a una página de soporte. Alguien sabe que pasa?
