GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,135 REPLIES 16,135
Exactly the same problem here (Gen II device in the Netherlands). I also saw some Spanish and Portuguese language posts complaining about the same issue posted not long before your entry, so it might be a global bug that's very recently crossed some wires. If so, I think (hope) that the issue will be fixed soon. Until then, I'm keeping an eye (and an email alert) on this comment section.
MR15
Bs As, Argentina same problem here....
Same problem here, im from Brazil
I Keep Getting a Message...
We Couldn't Authenticate Your Chromecast.
It's Very Frustrating. I Have 2 Devices and Both Will Not Connect. I've Tried Everything.
Me too!!
Same here ..
Same here, in Sweden. I have 2 second generation chromecast and 1 chromecast audio devices. They connect to my router but it is impossible to cast anything to any of them.
Today all three of my chromecast audio stopped working. They cannot be connected too. I reset the modem, wifi,phone and chromecast and I can’t connect to any of them.
Infelizmente tive o mesmo problema aqui no Brasil. Vamos aguardar o que o Google tem a nos dizer, mas acredito que foi mesmo descontinuado o suporte ao Chromecast! Triste!
TZman
Same here
anduso2
VIÓ... HOLA PÁSAME EXACTO, LO MISMO... YA EN EL SIRVE.
Starting some time today, all three of my Chromecast Audio devices started showing as "offline" in the Google Home app on my Pixel Table. Can't cast from Home (obviously) and the "Cast screen to device" option fails as well. Can't stream directly from Spotify from my Pixel Tablet and it fails for my daughter on her iPhone as well.
Rebooted the router (no other devices are having issues) and power-cycled the Chromecast Audio devices but they still show up as "offline". They show as connected devices on my router admin page so they did connect via WiFi/DHCP. I also don't see the built-in Chromecast SSID's that show up when they aren't connected to WiFi.
I'm guessing some sort of authentication to a back end service is failing on the Google side of things.
Anyone else having issues?
Same. Factory reset and now Chromecast cannot authenticate when trying to re-add
No warning, just bricked. I want my money back.
Stef69
Depuis cet après-midi, impossible de faire fonctionner mon Chromecast sur ma TV alors que je n'ai jamais eu de problème... j'ai tout essayé : réinstaller Google Home, changer les câbles d'alimentation, changer de TV, redémarrer ma freebox, mais toujours rien. Un message m'indiquer qu'il est impossible d'authentifier mon Chromecast...
Today I could not connect to my streaming services so I performed a factory reset and tried connecting through the home app. All goes well until it tries to authenticate.
I have reset router, restarted my Android phone and also performed another factory reset on Chrome.
I have tried all the proposed solutions on the forum without success. These problems seemed to occur in 2023.
Any proposed solutions other than going out and buying an updated product?
I am having the same problems in Argentina, it started failing today 9/3/2025, I found no solution.
Lo mismo. Soy de Argentina y de la nada me aparecio ese error No se pudo verificar Chromecast. Esto podría deberse a que el firmware del dispositivo no está actualizado. No lo quise reiniciar xq te pide autenticar el dispositivo y dicen que es peor.. espero que google responda algo.. ya sea una solucion o que diga si dejo de andar definitivamente. Pero veo que es a nivel mundial
Kev311
OMFG I've been having the same problem, started today! My Chromecast has worked for years, and any issue I managed to resolve within minutes. Not so today! It has been maddening! I've tried every suggested troubleshooting method, and nothing has worked. I am quite dependent on my Chromecast so this is infuriating.
There's no way to connect it to one's phone or PC and run diagnostics, so I am truly stymied.
I hope somebody discovers the solution. Is my Chromecast garbage now?
Same here Montreal, Quebec, Canada
WillIV
Can't get connected to customer service either. Phone call disconnects and I get a 404 error when I try to send a message.
Do you have the chromecast model; NC2-6A5 ?
Rob242
Yes I do. I believe that's 2nd gen model
Desde Peru Igual "No se pudo autenticar tu chromecast v2 ".  Visita support.google.com y nada
DDG1
Bueno creo que Trump corto el accesso para Peru.
Sudaca2025
Trump realmente puede chuparme el p... y el Golfo se llama Golfo de México ¡¡¡pinches gringos!!!
DDG1
Lol cambio de nuevo, ahorra se llama el Golfo de Trump.
I wonder if the location of the main server is in a state that no longer practices day light savings. So the security kicked in because of incorrect time between device and the server. I bet if we can change the system time on the Chromecast device back an hour.... It would work again.
Hmmmm 🤔 but I've had this chromecast device for years. I'm glad to hear it's not just me but I still am going nuts missing my shows lol
If you haven't done a factory reset, and your Chromecast still shows in your devices (you are lucky btw lol) you can change the date on your phone. But you will have to make sure it doesn't get to 9 March 2025, and I'd say never at all to be safe. If you can set your phone date back a week??? lol  It's not a server issue, it's a date in code/certificate authentication something-or-other. Can and will most likely be fixed but may be a bit. Good geek thread explainer. https://www.reddit.com/r/Chromecast/comments/1j7lhrs/the_chromecast_2s_device_authentication/
Copying part of the text: "Google issued an intermediate CA, presumably the one for all 2nd-gen devices, with a validity period of only 10 years, and it just expired. As a result, none of Google's official clients succeed in validating the device as genuine and they refuse to talk to it, including during initial setup. Google can fix this." ... "but it'll probably take a week or so, as it'll require syncing up with the release cycles of Chrome,"
An intermediary SSL Certificate expired on you CC device.  Google needs to either renew that certificate and resign all CC SSL certificates with the new intermediary SSL Certificate or come up with another solution that would be quicker to deploy on those millions of devices.
I've suspected the same. But, just to know, what's about those devices that somebody has reset to fabric?
I'm one of them 🙂 I've two c/cast, yesterday attempting to solve I've reset to fabric one of the two...after all following the troubleshooting guide.
You can re-add the chromecast easily, by putting the date of you phone 1 day back, in settings.
Many apps will now not be working, but the Home-app does. Enter the home-app, and add the chromecast. Now the home-app will see the chrome-app, and you will be able to do it.
After that, go back to settings, and put your phone back to the date of today.
You will still not be able to use the chromecast, but atleast Home-app will see it again, after that reset of your chromecast yesterday...
I did the same and that works.
But now we will be waiting for Google's updated firmware, I'm afraid. Good luck!
Ritesh1
Did anybody try ? Does it work ?
I reset my Chromecast but it says can't  authentication my Chromecast
TiagoNk
O meu Chromecast está apresentando o mesmo erro. Não consigo conectar, aparece um erro de autenticação aconteceu agora a tarde.
Plinio
Mesmo problemas:
Não foi possível autenticar o Chromecast.
Acesse support.google.com/chromecast para resolver o problema.
Tengo el mismo problema
Me sumo a la misma problematica, y el soporte no presenta ninguna soñucion a ese error
