Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-13-2025 03:48 PM - edited 03-13-2025 03:52 PM
If a user has conducted a factort reset, why not just roll back date on moblie device to pre certificate expiration date. Shouldn't this allow Chromecast device connectivity to recieve fix (updated certificate) ?
03-13-2025 03:49 PM
Awww man. I factory reset my chromecast before seeing this post.
03-13-2025 03:49 PM
Bonjour
Cela fait 3 jours que sa ne fonctionne pas , impossible de me connecter à Netflix je paye mon abonnement pour rien 😡
03-13-2025 03:49 PM
Mas quanto tempo isso vai levar ? Eu preciso do aparelho para trabalhar 😢 não consigo conectar. Fica um silêncio aqui no meu salão. Da pra imaginar um salão sen televisão e sem música?
03-13-2025 03:53 PM
Cuanto hay que esperar para que se actualice mi dispositivo?
03-13-2025 03:54 PM
Tem alguma previsão de retorno do funcionamento do Chromequest?
03-13-2025 03:54 PM
I think we all reset our devices at least 10 times in the first 15 minutes! What do we do now? It hasn't connected in 5 days!
03-13-2025 03:57 PM
My chrome cast second generation not connecting my WiFi
what is the solution
03-13-2025 04:27 PM
I've reseted my Chromecast to factory settings and had difficulties re-installing. Here's what I did. I changed the date to pre the 9th of march. Let's say the second of march. I started the installation process and it worked. After the Chromecast was back on line. I received the fix. And now it is working again. Don't forget to reset your date to the present day. Good
03-13-2025 03:59 PM
Please fix this problem soon, this is really unacceptable!!
03-13-2025 04:00 PM
I have removed the device from Google Home and did the factory reset on the device in a attempt to fix the connection problem. Will really appreciate guidance on how to solve this issue.
Thanks in advance!
03-13-2025 04:02 PM
Gosto muito do Chromecast, porém, faz um mês que a conexão é difícil ou não acontece, esse problema é desagradável por demais.
03-13-2025 04:02 PM
Thanks for the comms, was going crazy trying to fix last night and of course I factory reset. Assumed it was my old tv and thought I needed to replace! If this thread started Monday though, why did I just get an email? Would have saved a lot of effort on Thursday had I known.
03-13-2025 04:03 PM
Thank you, my Chromecast second gen is back. And I can stream again. I see in the technical info the update/fix. And it seems that the quality is upgraded to 4k. I hope anyone else's problems are fixed or gonna be fixed very soon. The Google "hockey puck" is one of the best products ever made. Simple, easy to use and smart.
03-13-2025 04:04 PM
The first thing anybody does is a factory reset!
03-13-2025 04:05 PM
Espero que vs conseguem resolver isso logo obrigado
03-13-2025 04:09 PM
We still waiting
03-13-2025 04:09 PM
I rang your support team to enquire about the problem and they didn't even know about the outage of the chromecast generation 2. He suggested a factory reset to me. And now
Because this message about the outage was only received today the 14th of March 6 days after the system failure, I tried to reconnect by doing a factory reset. What happen now for me?
03-13-2025 04:51 PM
Do as this post states and then wait for the firmware update: https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro...
03-13-2025 04:09 PM
Factory rest any updates on when it will work again
03-13-2025 04:11 PM
It’s good to hear that Google is working on it.
Two comments from my side:
1. I fully understand that products become outdated over time, and at some point, it’s reasonable to stop expecting support and instead upgrade to something new (after all, who still uses floppy disks these days?).
2. I own a Chromecast Audio, which is connected to my supersonic heavy receiver from the old days. These receivers were incredibly expensive, and by using the Chromecast, I can play Spotify via Google Home. As far as I know, Chromecast is the only device that enables this setup. If it stops working, I would be forced to buy a new receiver—an expensive change. That’s why I really hope Google continues to support Chromecast Audio and fixes this issue.
03-13-2025 04:25 PM
I use the CCA to cast hires music through PLEX, because even a newer AVR requires an analog input for the 2nd or 3rd zones.
03-13-2025 04:09 PM
Não consegui conectar
03-13-2025 04:12 PM
the problem is i’m not able to connect my device. How it Will be updated then?
03-13-2025 04:41 PM - edited 03-13-2025 04:42 PM
The devices update unsupervised, so, reading between the line, I'm assuming that, although we can't connect to them via the home app etc., they're still, hopefully, online... I also assume this is why factory resetting them is such an issue. If you factory reset, they can't go back online until we connect to them....however, we currently can't, so they'll be stuck in limbo until google give instructions on how to fix that more manually
03-13-2025 04:13 PM
I've reseted my Chromecast to factory settings and had difficulties re-installing. Here's what I did. I changed the date to pre the 9th of march. Let's say the second of march. I started the installation process and it worked. After the Chromecast was back on line. I received the fix. And now it is working again. Don't forget to reset your date to the present day. Good luck.
03-13-2025 04:14 PM
Problema para autenticar.
03-13-2025 04:14 PM
This has been down since Monday. What are we doing? I reset my x2 devices and now they can't be authenticated? I need help! Fix this
03-13-2025 04:15 PM
É uma vergonha uma empresa tão grande com esse problema que afeta toda comunidade de usuários da marca, que ainda por cima deixa sem data de previsão, sem ao minimo um respaldo..
03-13-2025 04:14 PM
@GoogleNestTeam escreveu:Olá a todos, obrigado pela paciência enquanto trabalhamos para resolver esse problema. Aqui estão as últimas:
Começamos a implementar uma correção para o problema com os dispositivos Chromecast (2ª geração) e Chromecast Audio, que será concluída nos próximos dias. Seu dispositivo deve estar conectado para receber a atualização.
Se você realizou uma redefinição de fábrica durante a solução de problemas inicial, ainda pode estar enfrentando um problema em que não é possível reconfigurar seu dispositivo. Estamos trabalhando para resolver isso o mais rápido possível. Continue verificando a página da Comunidade aqui para atualizações e próximas etapas.
Por favor manda como consertar não consigo configurar ele meu correio e
# agradeço
03-13-2025 04:16 PM
Manda .
03-13-2025 04:15 PM
2 días tardaron en decir algo!! Obvio que intenté reestablecer la configuración de fábrica.... 2 días!!! Increíble
Ahora miles tenemos que pagar por su ineptitud
03-13-2025 04:16 PM
I continue without chromecast, please give me the solution
03-13-2025 04:17 PM
I received a firmware update notification, then an error appeared "not possible to connect to the WiFi network" ( it was ) reboot your device, after the reboot not update message appears and still not working
03-13-2025 04:18 PM
Buenas!!me dice que no puede autenticar mi chromecast y que me comunique con soporte técnico, lo resetee también, quisiera saber si va a funcionar nuevamente.
03-13-2025 04:18 PM
Is cool Google, thank you for your product up to this point and I look forward to your eventual and awesome fix. I'm gonna go look at the moon or sky, Thank You for your service so far tho, been lit
03-13-2025 04:22 PM
03-13-2025 04:25 PM
I recently purchased a Chromecast because my new TV doesn’t have one built in.
I usually use Videostream to cast to my TV, but like many others, I’ve found it’s no longer working. However, I discovered that VLC still works perfectly for casting!
To cast using VLC:
Hope this helps!
03-13-2025 04:29 PM
I'm running Chrome with the work around from Reddit so I can still cast from PLEX while while I wait for the fix. A day without music is just not an option. 🙂
03-13-2025 04:25 PM
Yo reestableci de fabrica y consegui volver a dejarlo como si no lo hubiera hecho, simplemente cambia la fecha del tfno. Volvi a una anterior al dia 10/3/2025, empareje el chromecast y volvi a poner la fecha actual. Funciona!. Sigo sin poder enviar contenido pero al menos recibire el parche o actualización de ustedes. Tengo un samsung m51 android 12
