GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,151 REPLIES 16,151
Still waiting...14/03
pls hurry up all my paramout + trial is going to waste
Any news about progress for this issue?
Thanks for letting me know 4days later. I bought fire tv stick.
How do we know if the device gets the update?
Thanks. I hope you guys fix this soon. Still not able to cast using Chrome. Here in the U.S.
Isso realmente é um descaso com todos os usuários... Agora estou com um aparelho que não funciona e que não serve para nada. Preciso que arrumem o mais breve possível.
how do I know if my chromecast is connected to my wifi
不具合が起きてることを知る前に、出荷時設定にリセットしてしまいました。いつも不具合があるとそうしてたから。使えなくなったらどうなるんですか?
Desde el día 9 de marzo estamos sin señal, lamentablemente supimos del problema mucho después y reestablecimos los dos chromacast. El google homenaje ni siquiera funciona por favor, necesito una respuesta. Muchas gracias
Tengo problemas con mi Chromecast
It was a Chromecast assistant that advised me to reset my device and it’s been done many times.  How much longer before a fix ?
I reset my device how do I fix it...
Waiting  your update to fix the problem with my Chromecast
I could reconnect my device changing the date of my cellphone to before March 10th.
Please share the roll out plan. I am curious to know ETA for India.
I got the update at 9 AM morning, IND.
but it failed at 0%
WHAT DO YOU MEAN I CAN'T RE-SETUP MY DEVICE?
Are you going to replace it then?
Cuando solucionaran el problema todavía no lo puedo conectar
Ridiculous
My two chromecast devices still  not working.
Please advise.
My Chromecast Audio is back and works perfectly again
Hi
Will we get an email or text message informing us that the update has been done? As for checking on certificate expiry dates, Google Calendar can schedule a reminder of such events - just saying...
Mi dispositivo después del tiempo o de parche que estaban solucionando no he podido conectar mi chromecast, desgraciadamente reinicie el dispositivo hoy y aun así no se conecta
Even “ if “ you fix this issue in a few days how is that going to fix the $129 I spent on an Apple TV box  because the 3 chrome cast devices used in my house ALL stopped working . For a loyal customer of more than 10 years I will say I’m not impressed with your I.T. Team  , just saying !!!
Anonymous
Not applicable
If you performed a factory reset, you can still re-attach it to your "home". This will allow you to receive the new firmware with the updated CA certificate installed. Here's how:
Using your device (e.g.: Android phone or whatever you have the Home App on), change the date to March 1st. Then add the new device to your home per normal. It will find it as a new device and it will connect to the network and internet again. Then it will get the new firmware when it rolls out.
You're welcome 🙂
We tried the date switch and the phones still can't find it. We didn't factory reset we just removed it from the network. But now nothing sees it.
Ok, esperando....
Too much time, a company the size of Google should not take more than 3 days to resolve this.
This is setback for many customers. Please be consider this as a blocker and provide fix in 24 hours.
Of course I reset it as mostly everyone. How do we fix it?
5 days and don't have the solution? Are you Google or a low cost start up?
So how many more days?! Very annoying, have not watched my tv for days now!
I reseted mine days ago help please
 2 de mis dispositivos no están restablecido de fábrica y 1 si, estoy sin poder usar nada , xq no me llego solución a ninguno ni a los que están sin restablecer ni el que restablecí x favor exigo que solucionen este problema, no tengo acceso a ver tv
Is a marketing strategy to throw the Chromecast away and buy the new gadget?
You indicate that our devices must be connected in order to receive the update, but that problem is that our devices cannot connect.  Would you please clarify exactly what you mean by "connected".  Thanks in advance.
I already reset device. What can i do?
