GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,136 REPLIES 16,136
Update is finally here, thanks google
Thanks, it’s working again!
J'avais reconfigure en mode usine, merci de me dire comment reconfigurer
How patiënt doe we need to be to get an instruction how to restore the chromecast after factory reset?
So we have to keep the Chromecast turned on?? And then it will get the fix??
mine just got fixed ...you need to leave it plugged in....had my TV screen on then saw chromecast reboot happening on screen 0 to 100 % then a few more screens then back to chromecast photo page ready for casting . my other one I did reset on has not automatically reset so awaiting instructions for this .
All back to normal again 👍 thanks
Gostaria de saber quando o Chormecast voltará a funcionar?
Ya funciona!!
Me podrían mandar un correo por favor?
Trabajo de noche y para mi es más cómodo, muchísimas gracias
Issue is fixed. Please keep your TV on after connecting to your Chromcast. Google will push the update and system will automatically update and your Chromcast will start working after few restarts.
Thank you Google!
has anyone seen this patch work ?
Yes it works very well!
It works. Thanks
Hi, I removed my CHromecast Audio from mmy Google home before I saw this article. I can''t add add it back as the Chromecast Audio will not connect to the wifi. I have been without music for two days. When will this be fixed?
Fiz a restauração antes de informarem a pane e agora, qual será o procedimento?
I got the Update, now CC works fine again, thanks!
dede74
Can you tell me the version number you've got now, please?
Hi when can we expect a resolution to this
Anonymous
Not applicable
My ChromeCast is back to life. Thank you Google for fixing it!
Works again for me 😊
Thank you mine started working tonight.  I had done a factory reset, but I changed the date on my phone to Saturday and I got google home to connect no problem.
I did that too still not picking WiFi
Did u change it back afterwards
It's been days and days to resolve this. Like really Google? You were everything to us and now just disappointment.
Msfr saleh
 Hello, I'm back with a clarification, I searched to see if anything was solved and I saw that I can project the image from my phone to the TV but when I wanted to watch a movie on Netflix it doesn't connect. It knows it's connecting but it doesn't project anything. What could be the cause?
Yes, it is now working. Thank you so much. I believe we all will not face this issue soon and certificate would have long expiry date
I did a factory reset, but the solution that a user posted on Reddit to enable setting the device up again, which worked for me (Chromecast Audio):
- Set mobile device system date to 7th of March
- Open the Home app, and go through the Chromecast setup
- Once finished, reset the device date to automatic
Streaming still doesn't work, but at least the setup is done, and ready for the update from Google.
I've reset my device to fabric.
Hiw i fixed it. Manual set date on your phone or device on march 8th. Install your device again.
Once you did this, it will be able to update.
Worked for me. My gen 2 is back!
O que foi feito? Mudaram o sinal?
Agora jogo ele fora? Não presta mais? Me ajudem!
Thank you. I am now able to connect to all three of my Chromecast Audio devices. I needed to unplug them, wait a minute and then plug them back in to power. The devices reconnected to WIFI and then it seems they "updated" (after connecting to WIFI the indicator light blinked orange a few times then turned white). I could then "see" them as active on my Google Home. I am now casting my music to all of them.
Cheers.
A few minutes ago I unplugged my Chromecast Audio, wait for 2 minutes and I plugged it again: it works!!!!
Le problème dure depuis plus d’une semaine quand même ! Il serait peu être bon de faire rapidement quelque chose non ???
Hola google! Restablecer el dispositivo es lo que primero se hace cuando no funciona. Entonces deben empezar por solucionar urgente este problema. Pueden enviarme un chromcast 4g google tv, en compensación. Y resuelto el problema. Cuentan con mi mail.
Saludos
Me sumoooooo!!!!
Cabei restaurar o meu para configuração de fábrica podem me ajudar
Sí ya restauré la configuración de fábrica pero hace una semana que no funciona y estaba funcionando bien por favor si me lo pueden solucionar gracias
Thank You
It's been a few days, updates yet?
