GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,137 REPLIES 16,137
Zaka  tv
Did a factory reset and still having issues..
My two Chromecast Audio are both up and running again.
Work around for  factory reset by temporarily changing the system date to a date from before “the issue” first manifested itself and reinstalling the device worked also like a charm.
When can we expect to see a fix for us who did the factory reset initially?
Também estou me fazendo essa pergunta
OK estou sem uso.
Anonymous
Not applicable
出荷時にリセットしてしまっている場合どうすれば?
how do i changed date on Samsung phone?
emilainy
Vai nas configurações, gerenciamento geral, data...
Caewils
In your settings date and time
I confirm that one of our devices has been updated and it is working.
The other (we have two in two meeting rooms) not (I hope not... yet!)
Thanks.
Holy Cow! It has been over a week! An update on progress would be in order I would think. Perhaps an ETA? Seems a bit long for a major corporation to fix a problem...
Hello Google Team, when can we except the resolution on the issue? We are still unable to connect to Chromecast 2nd Gen.
Issue resolved by changing the phones date to 01-Mar-2025.  After the Chromecast will be configured, you can change the date to the current day
My Home app sees the Chromecast device but still throws a "Could not communicate" error when trying to setup
NandoC
Try this step:
Change the date on your smartphone to a date before March 8, 2025. Try redoing the Chromecast 2 setup from Google Home this way.
Come si fa a modificare la data dello smartphone?
Se hai un telefono con Android come sistema operativo devi andare su impostazioni (icona a forma di ingrannaggio). Dovresti poi entrare in Gestione Generale e selezionare la voce Data Ora. Una volta selezionata la voce Data Ora ti accorgerai che un pulsante a scorrimento è impostato su impostazione automatica.  Devi far scorrere quel pulsante verso sinistra in modo che ti sia possibile impostare la data manualmente.  Una volta che hai ripristinato il chromecast ricorda di riportare l'impostazione della Data e Ora in modalità automatica. Ciao
LesMike
We had that issue too until we uninstalled home and downloaded it again from play store. That solved the issue.
I did factory reset .. how long it takes to get fixed?
Cindy28
N’hésite pas si tu as des nouvelles..
Quand est ce que le problème sera résolu ? J’avais remis mon appareil en mode usine, cela fait plus d’une semaine que rien ne fonctionne et j’aimerais bien avoir enfin un retour…
Anonymous
Not applicable
So I did the factory reset. In that case do I need to wait?
Where is the solution PLEASE?
Buenas tardes,
Llevamos más de una semana sin poder utilizar el Chromecast, necesitamos una solución lo antes posible.
Confiamos en que ustedes están trabajando para solucionarlo, pero la solución se esta demorando mucho.
Gracias
Eu não estava ciente da atualização por parte da Google e por isso reiniciei o aparelho para a configuração de fábrica, agora não estou conseguindo realizar a conexão com o aparelho.
Alguém consegue ajudar?
google vai providenciar uma solução para isso dentro das proximas semanas.
basta volta a data do seu celular para o dia 08 de março, fazer a conexão e voltar para a data normal
come si fa a voltare i dati del tuo cellulare per il giorno 08 marzo
Acabei restaurante as configurações de fábrica... E agora?
espero urgentemente pois já faz 15 dias q estou sem acesso e pagando Netflix sem usar obg
Is there an update on the Factory Re-set issue?  Thank you.
oggi è lunedi, e non ci sono ancora novità sul ripristino di crhomecast, resettato al ripristino di fabbrica,  "Se è stato eseguito un ripristino dei dati di fabbrica durante la risoluzione iniziale dei problemi, è comunque possibile che si verifichi un problema in cui non è possibile ripristinare il dispositivo. Stiamo lavorando per risolvere il problema il più presto possibile. Si prega di continuare a controllare la pagina della community qui per gli aggiornamenti e i prossimi passi." si può avere un idea di quando sarete operativi per risolvere il problema
Vai nelle impostazioni del telefono e setta la data al 7/3/2025, quindi da Google Home riconfigura il chromecast, a questo punto una volta che il chromcast è riconnesso al wifi di casa si aggiornerà da solo risolvendo il problema di connessione. Dopo aver riconfigurato il Chromcast puoi rimettere a posto la data sul telefono. Per me ha funzionato.
Come on! More than a week to fix this? Please, put more effort into this task, it's annoying thousands of people...
Eu redefini o meu Chromecast
I performed rhe reset before I saw this. What do I do?
Checking in to see if there has been any update for those that did factor reset their devices yet.
Hi There,
I hope a solution is coming soon. My husband reset our while he was troubleshooting the issue and now we cannot get it to connect to our devices. Please provide a solution as it now cannot be used
