GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,155 REPLIES 16,155
Guldbaek
Jesus,
How long can a multi billion company take to fix your own fault? it has been 4 days without your device working.
Grow the **bleep** up
Ironis
I'm sure Jesus won't be able to help you. Also, your post must be the least mature one I've seen today, so there is clearly someone that needs to grow up. Not sure if it's Google 🙂
danielleking
how will we be notified???
XStefanino
Factory reset Is the first operation that I have done!
Jo34
Any update when this will be fixed a lot of people have no tv nothing just alone in this house there’s 2 tvs down at this stage we be better off to buy new devices just to watch tv if it’s to do with the security certificate wouldn’t you have know this was going to happen is this just googles way of stoping then no warning nothing any way hope this is fixed soon
Marco_rm
The problem has been there for 4 days. Aren't Google's IT people that good? 😔
Erselaco
I did the factory reset because i thought was a problem of my device.....there Is a solution?
Julio2025
Meu dispositivo Chromecast não está conectando mais ao wi-fi, fica dando erro de autenticação. Alguém mais com esse problema, e como resolver?
np9o9
Couldn't authenticated with the Chromecast device
Ancine
From yesteday I have the same problem with my Chromecast rev. 2, I cannot authenticate it with Google home, it is founded. I have resetted it to the fab settings. It shows on TV the message to use G. Home for configure it but G. Home see it on the Wifi network but at the end gives error that cannot authenticate it.
Please let me know ASAP how to solve this error.
Thanks a lot Antonio
Camilaprdt
Primeira coisa que o tutorial me ensina é resetar no modo fábrica
Então não temos culpa de ter feito isto
Mcd68
What is soon for you many days has past
andbeg
Коли вирішать проблему? Адміністрація щось робить?В цьому пристрої не так багато проблем щоб їх не можна вирішити?Коли все працюватиме?????????????
Louise2704
Hvor langt er med en læsning på problemet med gen.2 så vi kan konfirgurere og streame igen. Har desværre nulstillet i et forsøg på at fejlfinde så hvad er næste step??
Undrar också. Även jag återställde då det är standard…
Rroo1
Guess what was my 2nd try to recover? Factory reset, only to find this site 2 days later...
YussefSonda
😞 already factory reset mine it going to be a solution ?
JeniJ02
Mi chromecast no funciona, hace más de una semana que no se puede conectar y aún mo tengo una solución desde Google.
sergio75008
This is intolerable from a company as prestigious as Google, it hasn't worked for a week!!! I want a 4K Ultra HD Chromecast and a free Google Pixel 9a delivered to my home at 114 rue Pasteur 94120 Fontenay-sous-Bois - France. Thank you
Josephkg
Unable to connect mobile to TV
LGaitan
Chromecast cuando vuelven a funcionar los que fueron reseteados de fábrica tras la falla??
El mio no fue receteado y sigue sin funcionar! Dijeron q para esos ya estaba solucionado y q gradualmente iban a llegar las nuevas actualizaciones. Pero para los reseteados aun no hay solución y dudo mucho q lo haya seguro fue una estrategia para ir quitando estos dispositivos del hogar y q compremos nuevos
Idraka4
When do you guys fix this chrome cast gen 2 firmware issue?
victorhv
hola a todos, ya se sabe cómo recuperar el equipo si lo reseteamos de fábrica???
Juanmartin99
Hola yo compré hoy un chromecast de 2da generación y lo tuve q resetear obligado porq tenía los datos del antiguo dueño, y ahora no me anda desde Google dicen q no había q resetear por el problema pero si o si tenía q hacerlo
como soluciono este problema?
Hola estoy en el mismo caso que el tuyo yo uso 3 cromc uno anda pero resetee otros dos porque losmaravillas estos no avisaron nada,espero que lo solucionen
sergio75008
Miguel290978
Necesito que solucionen la falla de Chromecast, por favor
Maxabb
Resetee el Chromecast pero me aparece que no se puede autenticar
Clairmcl
I reset my chrome cast before reading the notice that there was a problem overall. Has ylthe fault been fixed yet and if so can you help me set my chromecast up now?
Hi, try to set phone date before 8 March and try again
angiediaz
Hi, my chrome cast doesn´t work for like a week and i restarted my cast, but it still doesn´t work.
KimhLarsen
How about you exchange 2nd and 3rd gen chromecasts for a new one for half price. You can't just hide without helping your customers. Regards, a very dissatisfied chromecast user
CDOV
Muy mal Google 2da generación no funciona desde Chile, soporte indica que se arreglará solo sin solución todavía hace mas de 1 semana.
Serpra65
Hace 5 dias que los clientes que confiamos en GOOGLE como empresa fuimos estafados con el problema del Chromecast. Siguen sin dar solución, ni respuestas, ni nada. Ameritan una demanda judicial global en  contra de la empresa Google que se traduzca en una fuerte multa y caída del valor de las acciones. Ni siquiera dan respuesta a los clientes. Google NUNCA MAS !!!
Efectivamente, ya con estos plazos y sin explicaciones detalladas sabiendo que entre sus usuarios hay entendidos se puede calificar como estafa, o rozando la estafa, lo primero es la transparencia y no la tienen.
