GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,146 REPLIES 16,146
What did u update? The app or device how to update the device??
For the one that you did a factory reset on, just do this and it will then be able to receive the firmware update:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro...
Perdón tengo dos dispositivos uno lo reinicie y el otro no el que reinicie lo volví a conectar con este método pero el otro que no reinice ya funciona y el otro no será que si se conecto a internet como puedo saberlo?
This is the solution for an problem to set back the date of my iPhone to 7 march 😳 really
Great , this worked thank you.
What worked. Can you please explain
AD57
Ok, thanks
Bei mir funktioniert es NICHT!
Thanks! This worked for me. Now just waiting patiently for my update.
A mi no me ha funcionado
Cdso333
Worked for me using another date, so long as it's before the 9th of March.
Also tried restarting my phone, rebooted my wifi, reinstalled google home, and factory reset my chromecast- again.
One of these eventually helped- just couldn't say which.
Alterar a data do celular ?
Yes.
Dumb question, it needs to be ON the entire time untill the firmware update from Google kicks in?
Yes, it needs to be powered on, i.e.: the power cable connected. Don't most people just leave it on all the time anyway?
I have it conected to the tv via USB port, that's why my dumb question
Not at all a dumb question. And that USB port may or may not be powered when the TV is turned off. I think on most tvs, they are always live whether the TV is on or not.
Already did that
Will this also work on iPhones? If we temporarily reset the date back? We all have been very patient…
Yes, it will work with iPhones.
Ok gona try now and let you knw. Ty!
Yes but I didn’t get the new firmware. The cc connected to my router so it’s now waiting for the update 😅
No ha funcionado. Ha llegado la actualización y no ha pasado del 0%. Ha indicado error de red y sigue averiado. ¿Ahora qué?
Done, and it worked. Now waiting for upgrade.🆗
Pbel
Kudos for this post, but for my devices I had to reboot them (unplug power cord, then plug back in).  Otherwise the update would not get applied
Cela ne fonctionne pas pour moi en France...
Thanks!  My Chromecast audio is working OK now. (But I did nothing!)
Great Sir, working fine now....
Anonymous
Not applicable
I had factory reset my chromecast, and this worked for me! It updated and everything, so back to full functionality. Thanks!!
I didn't need to change my phone date,  which is a bit silly,but my screen is greyed out,still.
Johnnyzero2 , my issue was same,  solve now thanks to you. but want to know how set 8 march can resetup chrome cast???
The cause of this whole problem was an embedded security certificate that expired on March 9th. Setting your phone's date to anything earlier than that "tricks" the Chromecast into thinking that the certificate is still valid.
Muito obrigada! Deu certo!
Anonymous
Not applicable
It appears today March 14, 2025 google is pushing these updates harder therefore anybody that reset their device and went through the procedure of resetting up the device by changing the date right now would be a good time to unplug your Chromecast device and then plug it back in that will force a reboot and will likely take the update.
Thank-you so much Johnny.  I'm not a very tech savvy lady. Lol I grew up in the dark ages. 🤣  I really really really do Appreciate your kindness.  And I do agree with your opinion that Google should pin this info to the top of this page. I only stopped freaking out the moment I tapped on the link you provided for the fix.  Again Thanks 😎👍☺️😁
You're very welcome.
Eu não restaurei,não mexi e supostamente não recebi a atualização,pois não estou conseguindo conectar por causa do erro que está dando na senha do wi-fi,não está sendo reconhecido.
thank you worked
Thanks all it worked.  Now just to sit back and wait
