Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-14-2025 07:37 AM
Ik heb hem wel weer kunnen koppelen via het aanpassen van de datum maar ik kan nog steeds niks casten. Verder denk ik gewoon afwachten ik kan niks updaten en zie ook niks of er iets is geupdate
03-14-2025 07:37 AM
Sigo esperando la re activación de mis equipos
03-14-2025 07:37 AM
Status and when Will you inform us how to be back on track when we already have reseted the device. This is bad…..
03-14-2025 07:41 AM - edited 03-14-2025 07:42 AM
**If you've already performed a factory reset, just do this:
03-14-2025 07:40 AM
Where and how will we recieve updates about this issue? Via this page, or E-mail?
03-14-2025 07:45 AM
Via the pinned status update at the top of this page.
If you've already done a factory reset and are waiting for the solution, just do this:
03-14-2025 07:40 AM
Last Google product bought? Why should i buy a Google product, if i know they pull the plug on me few years down the road....
03-14-2025 07:39 AM
No puedo conectar chromecast a mi tv,ni mi teléfono Android
Pueden darme solución en español.
03-14-2025 07:45 AM
Dicen que iddntificaron el.problema y que en los.proximos dias daran una actualizacion para que se solucione. Que debe estar conectado. Y que no lo restablezcas de frabica. Y si lo hiciste tambien tenes que esperar. En conclusion bla bla bla.. mas de lo mismo. No tienen solucion inmediata en ningun idioma
03-14-2025 07:43 AM
When did you fix it? How long did it take?
03-14-2025 07:45 AM
This message is a bit late…of course I already tried to reset it….
03-14-2025 07:47 AM
Factory reset is not the end of the world. Just do this:
03-14-2025 07:47 AM
all is done date changed to 1 march ,now app telling me to reset but i am not resetting it,now switching date n time to auto as direction given let c what google is up toooo
03-14-2025 07:48 AM
Hello Google Chromecast Team. Is this why my i-phone has stopped "communicating" with all my Chromecast devices?
03-14-2025 07:54 AM
Yes.
03-14-2025 07:49 AM
Is chrome cast issue fixed? Please advice.
if not then when or if you have work around solution please provide
03-14-2025 07:53 AM
Read the status update pinned to the top of this page. Google started rolling out a firmware update fix yesterday.
03-14-2025 07:51 AM
Ho già fatto il reset di fabrica. Cosa devo fare?
03-14-2025 07:52 AM
03-14-2025 07:51 AM
I make a reset according the old instruction, now it completly not able to connect. Hope fix soon.
03-14-2025 07:55 AM
03-14-2025 07:53 AM
Yo sólo vine a ver quiénes también resetearon su Chromecast intentando se actualice... como lo recomendó Google cuando existiera alguna falla...
03-14-2025 07:55 AM
03-14-2025 07:55 AM
Para los que resetearon el Chromecast a los valores de fábrica como yo, he seguido las instrucciones de una respuesta de aquí que decía cambiar la fecha del teléfono a antes del 8 de marzo, y después desde Google home volver a instalar el Chromecast. Y me funcionó! ( Estuve varios días intentándolo y ni me dejaba instalarlo). Ahora al menos ya se conecta a la wifi, esperaré a la actualización.
03-14-2025 08:24 AM
Con este video incluso puedes utilizar
03-14-2025 07:55 AM
I am a pensioner based in Johannesburg, South Africa, and use a 2nd Gen Chromecast to cast my entertainment to my TV screen. Regarding the "untrusted device" error with the Chromecast, I have seen in different forums that you are supplying fixes for the issue, but nothing has come through on my side. The Chromecast is still offline, still comes up with "untrusted device", and the cast firmware is still 1.56.275994, which it was before the error. It has been nearly a week, and I don't understand why my Chromecast has not received the fix when others in other countries have. It was only rebooted - without any success - and not reset to factory settings, and has been consistently connected to power and my wifi. Please advise when we can finally expect the fix, as I simply don't have the money to swap to another device.
03-14-2025 07:59 AM - edited 03-14-2025 08:00 AM
Supposedly the firmware update fix is being done as a phased rollout, so it could take as long as several days for it to hit your Chromecast. Google only started pushing it out yesterday. Patience.
03-14-2025 08:05 AM
Do we have any ”proof” of people acctually getting the rollout? A bit suspicious that it is actually happening.. feel like it could be a way to get loudest to calm down
03-14-2025 08:15 AM - edited 03-14-2025 08:16 AM
Yes, numerous reports from people who have received the update and are back up and running, although it still seems to be a small percentage of total users who have received it. Supposedly it's a phased rollout, so it could take as long as several days for it to hit all of our Chromecasts. Google even says as much in the pinned status update at the top of this page.
03-14-2025 07:58 AM
I did the 8th march thing and it worked but u can't cast but at least the device it's online hahaha , and now we are waiting for google to do the next thing
03-14-2025 07:59 AM
Olá, meu Chromecast não está pegando...
03-14-2025 08:00 AM
Ojalá exista pronto una solución.
Es impresionante la manera en que permitimos nos tengan cautivos.
En el trabajo ha afectado, no permite transmitir video conferencias ...
03-14-2025 08:03 AM
If you've already done a factory reset and are waiting for that specific solution, just do this:
03-14-2025 08:01 AM
Really disappointed to see that the fix is taking so much time ... Is this really google .. big question mark on the brand
03-14-2025 08:02 AM
Has anybody got the rollout of the fix yet?
03-14-2025 08:43 AM
03-14-2025 08:02 AM
...que nos tengan cautivos...
03-14-2025 08:03 AM - edited 03-14-2025 08:03 AM
Unfortunately, I factory reset before I was informed not to. Looking forward to this being resolved.
03-14-2025 08:05 AM
03-14-2025 08:00 AM
Oque esta acontecendo ?
