Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-14-2025 12:34 PM
Too late, I already factory reset my device and I'm UTTERLY angry at this. You have no idea on how impacted I was since I work with cinema distribution and work watching the titles in order to nationalise them, it's hard to watch a feature from computer screen! I truly hope you guys can be more didactic on your communications about your bugs, bear in mind not everyone understands well terms and stuff from tech niche as majority of people nowadays especially those ones who buy your stuff. I'm deeply disappointed at Google right now. Feel like a stupid.
I'll be waiting for the fix instructions for those who decided to factory reset, just hole it won't be a sphinx's enigma!
03-14-2025 12:49 PM - edited 03-14-2025 02:40 PM
Try this: On your phone manually change the date and set it to march 8 (prior to the issue). After that use the Home app, and in devices use the key add +, it will look for your chromecast, if it finds it (normally it does with this procedure) I advise to enter your WiFi password manually, and answer "not at this time " to the other questions, it should connect the Chromecast to your wifi. As soon as you see the clock back on your TV screen, it means it is online. Then is a matter of time to receive the patch. Today march 14 many users have reported they have already received the update. Leave the Chromecast on and wait since it can take some time. I advise to unplug and plug it back after 30 minutes if it has not been updated automatically, in order to force the update. Good luck
03-14-2025 03:15 PM
Have just done this and it works!
03-14-2025 03:36 PM
Thank you for your clear explanation, it works!
03-14-2025 03:43 PM
Obrigado pela dica de alterar no manual a data fora do automático.
Resolveu. Consegui.
03-14-2025 04:55 PM
Worked! Important part is the manual wifi part! Tu
03-15-2025 01:19 AM
Worked great! Thank you.
03-15-2025 06:34 AM
This worked. Thanks a lot
03-15-2025 09:13 PM
It worked, but after enabling the video in the settings of the device connected.
Thank you!
03-16-2025 04:37 AM
It worked great. Thanks a lot brother
03-17-2025 11:04 AM
Est ce que quelqu’un peut expliquer comment changer la date sur son iPhone SVP ???
03-14-2025 03:56 PM
Deveria processar pela perda financeira. Eu tô puto da vida com isso TB.
03-15-2025 01:19 AM
Another member suggested changing the date on your device. I changed mine to the 4th March. I'm now up and running and watching Loki. Can't find the original message but it worked.
03-14-2025 12:42 PM
Performed factory reset before receiving notice of outage from Google, so still getting "Could not communicate with your Chromecast Audio" error.
03-14-2025 12:43 PM
HOW DO I REBOOT IT???
03-14-2025 12:55 PM
Purtroppo avevo già ripristinato la chromecast, attendo quindi con ansia la risoluzione del problema. Grazie
03-14-2025 03:37 PM
segui le istruzioni che ha postato Condor, va a posto.
03-14-2025 10:48 PM
Stessa cosa avevo fatto io e ora non la app Home rileva il chromecast ma non riesce più ad installarlo...
03-14-2025 01:32 PM - edited 03-14-2025 01:33 PM
Olá, meu dispositivo não voltou mesmo, instalando novamente o aplicativo.
03-14-2025 04:59 PM
Just make sure your device is not stuck in factory reset mode, if it is do the following fix outlined by
user: johnnyzero2
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
03-14-2025 01:41 PM
4 days ago you advised factory reset of chromecast 2. Now you say don't so what do I do now??!
03-14-2025 04:56 PM
Have you done a factory reset? If you haven't just leave you device powered on, on your Wireless router. If you have reset your device do the following:
From user: johnnyzero2
03-14-2025 01:48 PM
Graças a Deus, voltou normal 😍😍
03-14-2025 01:50 PM
Quem redefiniu, é só mudar a data do celular pra dia 8 março deve conseguir parear novamente o chromecast , o meu voltou ao normal já
03-14-2025 01:51 PM
Last night I plugged them all in so they would be on my wifi, for any updates
And this morning,
All of mine are working now, even though I factory reset them before I knew they didn't want us to.
03-14-2025 02:10 PM
It works fine as of March 14th.
I hadn't done a factory reset, thank goodness, and my chromecast 2nd gen suddenly appeared on the Google home app
03-14-2025 02:10 PM
Ainda estou com problemas! Já reiniciei e nada! Estou aguardando a solução.
03-14-2025 02:11 PM
You saved my life!
03-14-2025 02:18 PM
Het is echt belachelijk voor woorden, dit is echt niet acceptabel.Waarom werden er geen mails verzonden.had mij hoop uren kunnen verhelpen!! Mijne werkt nog steeds niet omdat ik later zag dat er probleem was , ik had t apparaat gereset!!
03-14-2025 03:08 PM
Niet mauwen.
Gelukkig heeft GOOGLE het opgelost.
03-14-2025 02:23 PM
I had reset the chromecast before these instructions. I am trying to set up the chromecast again but without success. This is the message I receive: "unable to authenticate the chromecast device"...
03-14-2025 05:07 PM
Try this fix offered by user johnnyzero2
03-14-2025 08:57 PM
The work around that worked for me is to reset your phones' date to earlier than 8 March 2025. Run Google Home and add your device. You should follow all prompts. If you are in an area that Google has rolled out the update, you should see an update progress bar on your TV and the Chromecast will probably power reset twice. Don't forget to reset your phones' date. Open Google Home, see if your device is listed. Open you Streaming App on your phone and test casting. Goodluck.
03-14-2025 02:30 PM
Ok. All running😁
03-14-2025 02:44 PM
We’re back in business, thanks Google!
03-14-2025 03:03 PM
Yayyy finally!
03-14-2025 03:02 PM - edited 03-14-2025 03:04 PM
2 chrome cast audio work and have the xxx166 version. 1 i reset before, using setting the date back on phone I could connect it.
Thaaaaaaaaank youuuuuuu GOOGLE.
Netherlands
03-14-2025 03:12 PM
thank you!! 2nd gen is update to the New firmware 🥳
03-14-2025 03:33 PM
Bonjour
maintenant quand j’essaie de connecter mon chromecast ça deconnecte mon wifi
je suis obligé de redémarrer mon routeur pour avoir du wifi
mais de nouveau quand j’essaie de connecter mon chromecast plus de wifi
quand je n’essaye pas
ça fonctionne normalement
donc pour moi votre solution ne fonctionne pas
03-14-2025 03:35 PM
It's working, yey!!! Thank you.
