GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,137 REPLIES 16,137
Ran45
Done that now it's wanting g authentication
Lalylau_22
Lo restableci de fabrica en el momento que sucedió 🙄
Car02
Yo también lo hice pero hoy hice lo que estan diciendo de poner el aparato (sea computadora, sea iPad o celular) con la fecha del viernes pasado y volves a enchufar el chromecast y se te actualiza!! Después que termina tener que volver a cambiarle la fecha y listo
Bazalgette74
Unbe**bleep**inlievable.
What's wrong - do you have Elon Musk running Chromecast now?
Read the status update pinned at the top of this page. Google started rolling out a firmware update fix yesterday. It may take some time for the update to hit your Chromecast.
ema1960
Hola. Cuando dejó de funcionar mi chromecast seguí las instrucciones que me dió Google (REINICIARLO). Ahora no funciona. Por favor: darme instrucciones como solucionarlo. Gracias
scbrownt
Up and running again
thanks
Iwantmymusic
Pls fix before the weekend.
Read the status update pinned at the top of this page. Google started rolling out a firmware update fix yesterday. It may take some time for it to hit your Chromecast.
If you did a factory reset during the troubleshooting procedure, you'll need to do this to allow your Chromecast to receive the update:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
Thelo45
Até agora o meu não voltou a funcionar.
Desde o dia 10/03/2025!
Raffaelezanon
Non  funziona chromecast . Cosa devo fare?
Melomaniac
As of right now Everything is working fine!
Came back to life
2nd gen Chromecast TV devices and Chromecast Audio devices
I am in Ontario Canada but my brother in Poland still have no connection to his devices
My brother just confirmed that his devices in Poland are working fine now knock on wood!🙏
danilo20neves
Eu reiniciei o aparelho pra configuração original de fábrica, agora quando vou configurar o aparelho, aparece uma mensagem dizendo que não está tendo comunicação com o Chromecast
Volta a data do seu celular para o dia 8 e tenta de novo. Faz toda a configuração, ele vai reiniciar. Depois disso volta pra data atual que deve voltar
NoeliaPitt
Aún no puedo conectar mi cromecast
popularmoonligh
If did the reset option and can’t get it fixed. Set you date back to march 8th, it should log in again. Go back to the current date and you should be set! Worked for me
Killiansp
Te nez moi informé sur ma boîte mail
Andrifisio
Eu não quero saber de produtos novos,  de outras marcas e etc. Quando eu comprei essa m...., nao estava escrito que a validade encerraria dia 09 março de 25. Eu paguei e não foi barato. Já foi corrigido???? O meu aí da não está funcionando. Eu quero a solução O quanto antes, Google!!!! Agilizem!!!!
Relax. Read the status update pinned at the top of this page. Google started rolling out a firmware update fix yesterday. It may take some time for the update to hit your Chromecast.
If you did a factory reset during your troubleshooting procedures, you'll need to do this in order for it to receive the update:
Pq está me mandando ler atualizações? Eu já li e estou super relaxada. Quero que o Google veja as respostas das pessoas. Em diversos sites disseram que já está funcionando e é um MENTIRA. Eu não fiz redefinição de fábrica. Em nenh momento eu falei sobre isso. Quero resolução do GOOGLE. E daí?
Trenn es kurz vom Strom paar Sekunden dann kommt das Update automatisch, gutes Gelingen... Solltest du ein Reset gemacht haben stell dein Handy Datum auf den 8.3.25 und und richte es dann ein und dann nach dem Update das Datum zurück... Bei fast allen anderen Funktioniert das.gutes gelingen
Maurito
Arreglen la wea
Kalleho
Evert thing is now ok. I made reset on my Chromecast before I new about this problem. I set my phone to earlier date 03.03.2025 and made contact with Chromecast and could make set up as normal and after that brought back phone date as normal. I let tv and Chromecast stay on and after about 4 hours the update were made and everything is now back as normal. Ys Kalle
dfsilvad
Boa tarde!
Já restaurei como de fábrica 😔
DiegoFerreira
V7 B2
LucianoSantos
O meu ainda está dando erro
Infelizmente fiz a formatação do mesmo achando Que iria resolver o problema
 Qual procedimento devo fazer para voltar a usar novamente???
Julian_Munoz
Please email me with the solution as I alreasy factory reset my chromecast looking for a solution
The entire world reset theirs as that the the instructions listed in the list of tips. Ridiculous.
Manuroca
Hola , ya lo restableci a valores de fabrica y no lo puedo volver a configurar
