Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-15-2025 06:35 AM
Fixed. Turned the date on my phone to the 1st March to get connected. Then it downloads the update. Good to go! 😄
03-15-2025 06:36 AM
Y si he restablecido la configuración a fábrica porque no he visto este mensaje que pasa?
03-15-2025 06:37 AM
O meu problema não tá concertando o wi-fi e não tá funcionando nenhuma
03-15-2025 06:38 AM
I reset my chromecast
03-15-2025 06:43 AM
03-15-2025 06:27 AM
Como faço eu restaurei o meu pois não sabia dessa informação acima e agora o que eu faço?
03-15-2025 06:46 AM
03-15-2025 06:41 AM
I don't understand you
03-15-2025 11:01 AM
Try the above post, tapp the link please and try install.
03-15-2025 06:42 AM
03-15-2025 06:45 AM
03-15-2025 11:04 AM
If you set back the date om your phone of iPad you can easily acces the chromecast in the Google Home app. Thats the easiest way to remove your Factory reset.
03-15-2025 06:43 AM
If you've factory-reset your Chromecast, here's a workaround to set it up again:
1. On your phone, be sure to connect to the same Wi-Fi as the Chromecast would eventually reside on
2. Rewind the date on your phone 1 year backwards, so 2025 -> 2024. Uncheck the "automatic time" checkbox.
3. Open Home app on your phone and proceed to set up your Chromecast. It should work, albeit with a very long delays. Be patient.
03-15-2025 06:48 AM
I tried this but got stuck at this screenshot. Does it mean that it is updating right now?
03-15-2025 06:50 AM
I updated Google Chrome and changed the date on my phone (08/03/2025). Google Chrome has updated and is working fine now!!!
03-15-2025 04:01 PM
Funcționează
03-15-2025 06:44 AM
I thought it was some wrong with my phone
03-15-2025 06:45 AM
Si, ho già effettuato 2 ripristini hard su 2 dongle. Per favore, salvatemi.
03-15-2025 04:03 PM
Seteaza data telefon 2024 si configureaza cheomcast
03-15-2025 06:46 AM
Buongiorno purtroppo ho già ripristinato la mia chromecast di 2 generazione ora non mi funziona più come posso fare ?
03-15-2025 06:58 AM
03-15-2025 10:30 AM
CAMBIAR FECHA AL 7 DE MARZO, E AVANTI
03-15-2025 06:47 AM
Pp não funciona
03-15-2025 06:49 AM
Of course I made a factory reset as a step in my own fault-trace when I initially lost contact with my Chromecast gen2-device. Learning about that a certificate expiration might have caused the situation I did the following:
- Initially - no contact with the CC2.
- A factory reset of the CC2.
- A manual reset of my Iphone to a past date like March 6.
- Configuration of my CC2 from scratch through the Google Home app in IOS.
- A reset of my Iphone to current time.
- A forced restart of the CC2 (for safe measures).
- After these steps I am able to cast to the CC2 again.
I hope this help someone 🙂
03-15-2025 06:52 AM
***There is a known fix to recover from a factory reset, and it's ridiculous that Google hasn't pinned that information to the top of this page!
Literally 90% of the people now posting here are saying "I've done a factory reset, now what can I do?" or "Any update on a fix for people who have done a factory reset??".
In the meantime, I've been posting the solution everywhere I can to help those affected:
03-15-2025 06:53 AM
Eu recet3i meu chormecast não estou conseguindo conectar novamente.. oque faço??
03-15-2025 06:54 AM
Please hurry Google. Many of us rely on chromecast so we can watch things on a big screen. Watching things on my phone is well, not as great. Most of us are still waiting since a factory reset is advised as a step in Chromecast recovery just about everywhere and I'm sure we all tried it... at least once. Please do a good job and try not to take too long.
03-15-2025 06:56 AM
Waiting for fixing.
03-15-2025 06:57 AM
J'ai lu qu'on devait simplement redémarrer le chromecast, est-ce le cas? Je n'ose pas rien faire!!
03-15-2025 07:08 AM
Pour moi redemarrer ca a pas marché. Reinstaller avec le telephone avec la date 1 Mars. Ca connect pour un update et ca marche 👍🏻
03-15-2025 07:12 AM
Bonjour. Non, vous n'avez rien à faire. Je viens de "récupérer" mon Chromecast, sans rien faire. Voilà ce que j'ai fait : j'ai allumé ma télé et j'ai tout de suite vu sur l'écran qu'une mise à jour allait s'installer. Puis il y a eu un redémarrage du Chromecast, sans intervention de ma part, puis le Chromecast était à nouveau opérationnel. Je n'ai strictement rien fait, j'ai seulement suivi sur l'écran de ma télé l'avancée de la mise à jour.
03-15-2025 06:59 AM
Eu fiz reposicao de fabrica e agora ? Continua sem funcionar
03-15-2025 07:03 AM
03-15-2025 08:25 AM
Eccezionale funziona ❤️
03-15-2025 07:02 AM
El día 9 cuando dejò de funcionar siguiendo sus instrucciones lo reinicié, 4 dias después anuncian que no se reinicien, después de una semana sigo sin poder utilizarlo y sin una solucion por su parte , es una vergüenza.
03-15-2025 07:03 AM
So I have a number of chrome cast audios running 4/5 depending.. after they all seemed to stop working have factory reset 2. Subsequently the others not reset now work again although not reliable. Waiting for suggestions/device update for re-connecting factory reset devices..
03-15-2025 07:06 AM
Nothing will work untill they update.not your fault
03-15-2025 07:07 AM
03-15-2025 07:11 AM
Ripristinato più volte non va
03-15-2025 07:03 AM
Eu reiniceiei ele restaurei padrão de fábrica, o que eu faço agora??? Isso antes de receber esse e-mail 😢
