GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,123 REPLIES 16,123
Daniel37
Estou tentando conectar SP, 15/03/25, sem sucesso. Chromecast 2° geração.
  ***If you are one of the many users who have done a factory reset, you'll need to do this....
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro...
Ale1980
Não tem uma previsão para concertar isso?
  >> If you are one of the many users who have done a factory reset, you'll need to do this...
Dante515
I'm STILL unable to connect BOTH of my Chromecast devices.
 ->If you are one of the many users who have done a factory reset, you'll need to do this...
Analaura
Oi quando vai ser arrumado o meu diapositivos e como??
Liliyraquel_7
Y como sabré cómo volver a configurarla? Me llegará algún correo?
MP60
when are you going to provide the instructions for the ones that factory reset.
 **If you are one of the many users who have done a factory reset, you'll need to do this:
SE87
This is terrible for such a huge company, I've been using my chrome cast for years. And ive always had issues with connectivity. Usually resetting the cast does the trick. However upon looking up on the Web page it says not to factory reset the chrome cast this is annoying because I know can't see a fix for this, alot of upset children. Thanks to Google
DankerCorrea
Poderiam me dar pelo menos uma data para eu poder conectar novamente.
rajeswary
$rajes@£&$¥?
Isha12
I couldn't cast or get connected , my device shows offline and I have done factory reset what should I do to get it updated
SamaSama
I did a "factory reset" while in the dark about the reason for the problem. Why is Google taking so long to figure out a solution???😡
Anonymous
Not applicable
How do I fix this? I had already pressed the restart button on my chromecast
Mauma
I already reseted it, it's actually the first thing I tried to reconnect and now I can't connect to wifi so I can't update with your fix. Please help.
  If you are one of the many users who have done a factory reset, you'll need to do this.m:
Kamanta
Bientôt Dimanche et toujours impossible de lancer Chromecast, bientôt une semaine et pas de solution ? J'ai réinitialisé mon appareil, bien avant que vous ne disiez quoique ce soit, et je suis maintenant après plus de 2 heures devant le même écran où ma connexion internet ne se fait pas sur l'appareil qui de ce fait n'existe toujours pas quand je veux cast depuis Amazon Prime ou YouTube. C'est quand vous voulez....
Nest75
Here is how it works.
 You have to be logged in to your Google account (so Google sees you and can send you the fix)
In the Google home look top right to see which Google account are you logged in
SergiTallon
Good evening,
To update the Google Chromecast certificate on devices that have been factory reset after the failure on March 9, 2025, the solution is simple:
1. Change the date on your mobile phone to March 1, 2025.
2. Re-sync, set up, or add the Chromecast to Google Home as usual.
3. Once the Chromecast connects to the WiFi network, the certificate will update automatically, and the device will function correctly.
Sergi Tallon
Pec
exceto áudio que não funciona ainda
Siiiiii!! Genio te amo!!
Yesssss!!! Genius I love youuuu!!!
Did that and it set up but still said tv online so in the end didn’t work
EvaPeruca
Cuando se soluciona? No funciona mí Chromecast y lo reinicie a fábrica. Ahora no lo puedo instalar.
Prueba de cambiarle la fecha en tu móvil  a 7 de Marzo y vuelve a hacer el proceso de configuración del Chromecast.
Saludos
Prueba la solución que posteé. Tal vez también te funcione.
MisterFox
Possible solution that worked for me despite factory resetting the Chromecast.
1. Change your mobile phone's date to March 1, 2025 manually.
2. Open the Home app and add your Chromecast the same way you did the first time. It will update automatically.
3. Once the update is complete, test that it works. In my case, it worked perfectly.
4. Don't forget to set the current date to the mobile phone you used to set up Chromecast.
I hope this is at least a temporary solution and you can use your device.
Peace and love. ✌️
Den9
Configurei, preciso da atualização
Fabiofliege
Boa noite.
Aí dá não tem nenhum prazo pra resolver esse problema?
Daviluiz
Eu tentei várias vezes e segui as estrusoe mais não foi
Gush
Hola, cuanto tiempo más hay que esperar una solución? Como puede ser que una compañía de su tamaño esté hace una semana con este inconveniente ??? Hace pensar que es a propósito para adquirir un producto nuevo.
morganb09
Are there any updates today, for those of us who were instructed to do a factory reset by a representative?
