GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,122 REPLIES 16,122
hansspierings1
Wanneer kan ik een reactie van verwachten?
Ik heb 2 chrome cast. 1 werkt wel de andere niet....hoe kan dit?
Vriendelijke groeten Hans spierings
Ste86
Anche i chromecast di 1^ generazione sono bloccati. Io ho fatto reset di fabbrica prima di saper di questo problema e ora non si associa piu!!
Bman333
It's been nearly a week now and I'm still unable to connect to my chromecast.
Do you have any idea how much longer it will be before the issue is resolved please ?
J1103
Je moet op je smartphone je datum terug op 8/3 zetten. Dan je chromecast volledig opnieuw installeren. Zou hij terug een nieuwe update doen. Dan geduld hebben.
Datum kan je wel terug zette dan ondertusse.
2 dagen ongeveer bij mij. Ondertussen stream ik terug 👍
Johan België
Vivimfloirinha1
Só preciso saber o que será feito pra retornar com a utilização do equipamento?
Boni1
Por qué no me reconoce mi chomecats
ChristoferCastR
If factory reset was done, will you provide instructions, to set our device back, here or on email?
MassimoB
I made reset on Chromecast with the little switch on side. Ma no change. I am waiting for further instructions
Katefielding44
Is there any update for those who reset their device please?
lbwwilliams1066
I performed a factory reset...so couldn't connect since.
But I've just fixed the issues by doing the suggested change of altering thr phone date to 01/03/25.
It's now connected and is performing the firmware update.
Hope this works for everyone else.
That's great. But your post could give other users the false impression that simply altering their phone's date alone will somehow fix it. There's actually a bit more to it than that.
 Detailed instructions here:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
johnnyzero2
For all the people who performed a factory reset during their initial troubleshooting, this procedure will allow you to reconnect your Chromecast to your Wi-Fi network, so that it can receive the firmware update fix that Google started rolling out on 3/13.
1) Temporarily set the date on your smartphone (or tablet) to March 7, 2025 or earlier. If you don't know how to do that, see below.*
2) Use the Google Home app to re-setup your Chromecast by adding it as a new device (+). You still won't be able to cast, and the device will be grayed out in the Home app, but that's ok. Most importantly, it'll now be reconnected to your Wi-Fi network so that it can receive the firmware update fix.
3) Change your phone's date/time setting back to Auto now.
4) Sit back and wait for the firmware update from Google to be installed. This should restore your Chromecast to full functionality.
Note: Supposedly it's being done as a "phased rollout", so it could take a while for the firmware update to hit your Chromecast. Also, some have reported that power-cycling your Chromecast (unplug/re-plug the power cable) will sort of "provoke" the firmware update to be installed.  Patience.
*How to change your phone's date/time settings:
For iPhone/iPad: go to Settings, General, Date & Time. Disable "Auto" and manually set the date to March 7, 2025 or earlier.
For most Android phones/tablets: Settings, General Management, Date and Time. Disable "Auto" and manually set the date to March 7, 2025 or earlier.
**Google REALLY should pin this information to the top of this page.**
Celsosantos1
Acabei reiniciando o meu para ver se funcionava...mas não está funcionando..
Sudi
So has it been done? I still am unable to cast my devices? I have already factory reset my device..i would appreciate a guide to stepwise resinstall in my inbox pls…
Martin26
No conecta
sergiocolluna20
Quero usar meu Chromecast
sergiocolluna20
Parou de funcionar
JulianaR
Hola! Si cambias la fecha de tu dispositivo a una anterior al 09/03, podes volver a configurar a tu Chromecast a wifi y luego se actualizará solo
mihirkalotara
I trust Google So Much but at this Time I Think Your Policy Made With the Perpose Of Profit, thats why your Compny Cant Work On Old Device Please Reslove this Problem As Fast As You can. its All On You. We Bought your product for use not for just waiting of your update, and Thats Not a vegitable Which is Expires After some Time, Dont Make Your google Image as Chinese Product Which is made With the perpose Of Use And through or Just Use 5 to 10 Times. Resolve This Problem.
>>>If you performed a factory reset during your initial troubleshooting, you'll need to do this:
Paula16
Un desastre! Hace una semana que estoy sin poder usar mis apps pagas xq no puedo vincular el Chromecast
** If you performed a factory reset during your initial troubleshooting, you'll need to do this:
Guru488
Sir
I reset Chromecast 2nd generation device now one massage show could not communicate with your Chromecast setup not done please help
alina3
i factory reseted my device kinda so what do i do now
Greg20
I had already factory reset one of my 2 devices before reading this notification. One that has not been reset is now back on. The other that was will still not connect. What are you going to do about this.......as it is your problem and I would think a lot of people have done the same.
****** If you performed a factory reset during your initial troubleshooting, you'll need to do this:
Toroman
Esto es inaceptable, llevo mas de 2 semanas sin poder usar el dispositivo, busqué ayuda(que fue difícil de encontrar) y me indicó que reseteara el CC y ahora esto... Que vergüenza... Y a mi quien me devuelve las suscripciones? Al final lo mejor serà comprar un dispositivo pirata que lo tenga todo... Total por el precio de esta mierda.
cmingorance82
Yo resetee el dispositivo, pero he podido instalar la actualización cambiando la fecha del teléfono a una anterior al 9 de marzo. Una vez instalada la actualización, he vuelto a cambiar la fecha del teléfono y todo funciona ya con normalidad.
That's great.
marcosdejesus
Resetei e agora?
