GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
****** If you performed a factory reset during your initial troubleshooting, you'll need to do this:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
Toroman
Esto es inaceptable, llevo mas de 2 semanas sin poder usar el dispositivo, busqué ayuda(que fue difícil de encontrar) y me indicó que reseteara el CC y ahora esto... Que vergüenza... Y a mi quien me devuelve las suscripciones? Al final lo mejor serà comprar un dispositivo pirata que lo tenga todo... Total por el precio de esta mierda.
cmingorance82
Yo resetee el dispositivo, pero he podido instalar la actualización cambiando la fecha del teléfono a una anterior al 9 de marzo. Una vez instalada la actualización, he vuelto a cambiar la fecha del teléfono y todo funciona ya con normalidad.
That's great.
But your post could give other users the false impression that simply altering their phone's date alone will somehow fix it. There's actually a bit more to it than that.
 Detailed instructions here:
marcosdejesus
Resetei e agora?
Conz195
5 years later.......
-----> If you performed a factory reset during your initial troubleshooting, you'll need to do this:
ravirajukommire
Dear sir/ ma'am,
As I had already did the reset the device and now it is not getting connected. What should I do. I am trying all the possible ways to set up the device to my tv, But I am unsuccessful in installation. Guide me please
Thanks and regards,
Raviraju
Smarts1977
When will there be a fix?
Ive reset mine to factory default
Dina59
Bom dia ,já resetei ontem a noite ,e agora não sai da tela GET THE APP E NAO CONSIGO IR ALÉM.
--> If you performed a factory reset during your initial troubleshooting, you'll need to do this...
lamapi10
no working
-----> If you performed a factory reset during your initial troubleshooting, you'll need to do this...
Flores2410
Porque no puedo conectar mi celular a la tele hay un error por favor solucionen pronto el problema.
*------> If you performed a factory reset during your initial troubleshooting, you'll need to do this:
johnnyzero2
For all the people who performed a factory reset during their initial troubleshooting, this procedure will allow you to reconnect your Chromecast to your Wi-Fi network, so that it can receive the firmware update fix that Google started rolling out on 3/13.
1) Temporarily set the date on your smartphone (or tablet) to March 7, 2025 or earlier. If you don't know how to do that, see below.*
2) Use the Google Home app to re-setup your Chromecast by adding it as a new device (+). You still won't be able to cast, and the device will be grayed out in the Home app, but that's ok. Most importantly, it'll now be reconnected to your Wi-Fi network so that it can receive the firmware update fix.
3) Change your phone's date/time setting back to Auto now.
4) Sit back and wait for the firmware update from Google to be installed. This should restore your Chromecast to full functionality.
Note: Supposedly it's being done as a "phased rollout", so it could take a while for the firmware update to hit your Chromecast. Also, some have reported that power-cycling your Chromecast (unplug/re-plug the power cable) will sort of "provoke" the firmware update to be installed. Patience.
*How to change your phone's date/time settings:
For iPhone/iPad: go to Settings, General, Date & Time. Disable "Auto" and manually set the date to March 7, 2025 or earlier.
For most Android phones/tablets: Settings, General Management, Date and Time. Disable "Auto" and manually set the date to March 7, 2025 or earlier.
****Google REALLY should pin this information to the top of this page.****
Cambiato data e fatto tutto. Speriamo di risolvere al più presto
まい
繋がらないのでリセットしてしまいました
Topogigetto69
Io purtroppo ho ripristinato il sistema. Rimango in attesa per la risoluzione, spero presto. Grazie
- > If you performed a factory reset during your initial troubleshooting, you'll need to do this:
Sohitkhandelwal
How long will it take for company like Google to fix this issue
TiviotPie
Regrettably I had already done a factory reset before becoming aware of this problem.  So i restarted my ChromeCast 2nd generation  by setting the date and time on my iPad to March 8th (day before  it went wrong) then ran through the Google Home set-up instructions.
  This time it all worked fine.  Deleted the Google home app afterwards then reset date/time to ‘automatic’ on the iPad. All tickety-boo now. Just waiting now for the Google firmware to get loaded down automatically one day soon. But at least it’s all working now.
mitesh1984
Good evening. Last 3 days google chromecast not connecting with mobile and showing troubleshooting. Please can you help in this matter.
CaroToti
Restaure de fabrica el Chromecast y no puedo volver a conectarlo.
Solangeo
Já redefi estou sem o uso em meus dois aparelhos como devo proceder???
---> * If you performed a factory reset during your initial troubleshooting, you'll need to do this:
Micetherice
get your phone on plane mode. change the date to 2024/05/01. connect to wifi of your reset chromecast. follow instruction with google home.
Why-no-worky
It takes one of the biggest internet companies more than a week to update a certificate?
WOW me some more.
Will you be pro-rating everyone's streaming subscriptions for loss of use?
-let me guess your answer.
Taking the weekend off?
Trevor7
I have a problem with my chromecast 2, i cant connect to my new tv and my device because doesnt function factory reset on this device.
