GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,151 REPLIES 16,151
sap4001
What to do if you already factory reset the device ?
Tyfer1313
Consumers should be compensated for such an issue impacting their services. Not only have we paid for the Chromecast, but we pay for multiple streaming services which we can no longer access as a result of Google's error and/or neglect of a customer population. This all seems very suspicious, how can anyone rely Google after such a disaster?!
Do better Google! 😕
dbajaj26
Please provide me the solution for this. As I already factory reset my chromecast device and now it's not configuring with my TV.
Sirnjonjo
48hrs later no fix?
Anj_ali
  1. I am faving tte same issue. While chromecast from you tube it shows error " Untrusted device"  This could be caused by outdated firmware. Please resolve the issue I have already looked overnet for this issue  but didn't able to find any solution and wasted so much precious time. My time is also valuable
Ross64
How much longer until this is fixed?
raulfergaeza
If you need help the bug is in this code line:
if today() > 03/08/2025
        return ('Error Authentication');
MikeyP66
Before coming here it's obvious the 99% of people have already tried a 'Reset' , thinking they have set something up wrong.  Come on Google... So unlike you to drop the ball.  I have committed to Google Home and have 26 devices... Main reason I went with you is for the 'Chromecast Audio'.  You need to fix this quickly, as you will loose support and also all the recommendations I give for new users.
Neelpat531
@GoogleNestTeam wrote:
Will this be fixed with an update? How long do you think is the wait roughly? Weeks, months?
Thank you
Exactly! They don't even inform of a possible ETA for the fix.
Inimini
The warning not to factory reset comes too late... You try everything when something doesn't work. Unfortunately not the first time either...
ChromecastUser2
Set the date on your smartphone back to march 7th. Then install your Chromecast through Google Home. It won't work for steaming anyway but it is connected to your net ready to receive the fix
MarieKim65
So is everyone still out
yep because I didn’t know about it I factory reset my device
MarieKim65
So is everyone still out ?
oh yeah I’m one the probably 100’s that reset their devices because I didn’t know  the problem was google
how long until the problem is fixed ? this is my only way to watch TV
Kristy4178
How will we be notified of what to do next?
osamu
Please resolve this issue as soon as possible. I am in so much trouble.
Ryansr1
Wish it can be fixed soon.
Alfred555
I will never buy any GOOGLE products again
SanderL
I already returned to factory settings my Chromecast Audio. Tell me what I have to do to turn it back to normal?
Mardecel
GEROU VÁRIOS PROBLEMAS PARA MIM, VÁRIAS PESSOAS QUE RECOMENDAVA E RECOMENDEI ...
TODOS ME XINGARAM, RECLAMARAM E QUEREM SOLUÇÃO DE MIM, APENAS UM USUÁRIO QUE AMAVA O CHROMECAST...
ESTOU MUITO TRISTE E SEM CHÃO 😢 😞
RECLAMEI MUITOS ANOS DESSA INTENSAS ATUALIZAÇÕES CONSTANTES, IRRITANTES E Desqualificadas...
A BOMBA 💣 ESTOUROU AGORA E AO INVEZ DE RETIRAR A ULTIMA ATUALIZAÇÃO E MANTER A ULTIMA FUNCIONAL ATIVA ... NÃO ESTA QUEIMANDO O NOME DA GOOGLE...
ESTOU FRUSTRADO...
ALÉM DA RAIVA DE MAIS DE 24 HORA ...
PARABÉNS!
jessst
Doesn’t feel like your response is urgent enough for how much of an issue this is
vibeketoemte
It's all about the money by now, it seems highly unlikely that a billion dollar company like Google would, in 2025, need several days to fix this, with no information provided.
Most likely, they're awaiting the customers to take matters into their own hands, buying a new Chromecast and stop complaining about the current one.
Can anyone recommend a new streaming device, not made by Google?
DanielSibisan
I have several Chromecast Audios conected on classic Stereo Systems. If Google will no longer support the Chromecast Audio then what? Maybe you should make it open-source? It will be a pity to throw away such a simple, beautiful, usefull and High Res equipment for some Low Res active speakers or super expensive equipment from other brands... I use Google everywhere, my phone is a Pixel... Google is simple, efficient and performant. Please do not let us down!
Mohsin9129
Google has acknowledged the problem and is actively working on a fix. In the meantime, some users have found a temporary workaround by resetting their Chromecast and manually setting their phone's date to a day before the issue began (prior to March 9, 2025). This method has allowed them to add the device back using the Google Home app.
Robynandtinker
The same thing happened to me last night, having the same issue today. It’s really annoying. Would be good to know if it will be fixed??? Perhaps upgrading to the new chrome cast would work? I feel like everyone should be given new ones. Would be good to have been notified
Robynandtinker
could you please advise when this will be fixed?
thanks
Terrie
The previous help info says to factory reset and can't authenticate and now you're saying - in red - don't factory reset? Please help
ChromecastUser2
Please respond to us once this issue is resolved.
PaulKlinkhamer
Please FIX THIS if you want your customers to not boycot Google. There are 100k Chromecast users that can’t use there product for 2 days now… that’s not oké for such a big company 😱
Presidente_75
Ciao a tutti
Posto una soluzione temporanea per chi avesse fatto il reset di fabbrica del dispositivo.
Entrare nelle impostazioni dello smartphone, cambiare manualmente la data con una antecedente l'8 marzo.
Aprire l'app Google Home e configurare ora chromecast che viene rilevato e può essere riconnesso alla rete internet.
Lo streaming verso Chromecast non funzionerà comunque, ma per lo meno, appena verrà rilasciato un aggiornamento, il dispositivo riuscirà ad aggiornarsi
Super_Dave_Osb
Do you need to replace your Chromecast or are you finally going to fix it? It's getting long without an answer...
Evak
Inmiddels zijn we 24 uur verder. Weten we al hoeveel tijd Google nodig heeft om zoiets simpels te verhelpen?
EmD
Ummm, so how will we know when the problem is fixed? And if we already did a factory reset because this information wasn't glaringly obvious when Chromecast went down? If you go to troubleshooting it literally says to factory reset.....
SLaursen
Have reset my cromecast - sorry, please send instructions to getting started again.   #
Pucksterv
Replying so I can stay updated on this issue. Unfortunately I already reset my device to factory reset.... Hoping it will work soon
Anonymous
Not applicable
Nu är det väl bara att vänta på information, när detta är åtgärdat. Jag har också fabriksåterställt den.
letoute
Shall we all switch to other browser, Hotmail or Apple mail,  other search engine then google, let's say Bing..... ??? Let 's see how this affect their advertising income......    Get it fixed!!!  You can still buy them new on E-bay (Chromecast audio).....  WTF.....      I use 3 of them.... connected with optical cable to decent Hifi Amplifiers and speakers....  No interest in crappy bluetooth speakers and sound.....
Nimitha
I did  the rest , now facing the issue " we couldnt authenticate your Chromecast please visit support"
John9999
Prior to this (very late) update, your own troubleshooting steps instruct you to factory reset as one of the steps!
Bp55
For those of us who factory reset before coming here, what do we do now?
