GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,147 REPLIES 16,147
AV1976
"Do not factory reset......" Well, I hope there will be a solution for all 'factory reset' early adopters...
doofygoof
Factory resetted. Tried changing time but now I cannot even Connect to chromecast device. My phone cannot find the device. Am I done?
it is a google issue, just wait
WillIV
Unfortunately we have to be patient to wait for a fix from Google. I'm not sure why it's taking them so long.
Barbicardel
Any update, please?
Florencebettini
2 chromecasts en rade ducoup j’ai acheté une box tv et j’ai réinitialisé un des 2 après j’ai 3 tv donc comme ça chacune aura le sien . Ça m’a quand-même bien pourri mon dimanche après-midi et ma soirée , je me serais bien passé de dépenser 58€ en ce moment !
J’attend donc les nouvelles et les instructions.
paco1
any estimated timing?
Emusk
I demand a refund
Emusk
I will buy your company and sack everyone responsible for this outage
johnnyzero2
Workarounds posted on Reddit and other sites, even for those who have done a factory reset. Worked for me, until these dopes see fit to issue a proper fix.
Do you have a link or instructions for the workaround you found? I was able to get mine connected back to the Internet but still unable to cast to it.
forget, it is a google server issue, not yours
Excellent instructions for workarounds here, even for those who have done a factory reset. Worked for me. I can now cast from my Android phone to my Gen2 again. Good enough, until Google issues a proper fix.
https://mensfeld.pl/2025/03/bringing-your-chromecast-back/
Thank you!
Hackneyzz
Hi. Any indication of time frame when this will be resolved?
Paul-Maes
Reset is reeds gebeurd. Kan u spoedig instructies sturen?
agibdk
Why is this taking so long? At what time and date do you expect to have deployed a fix?
Alejo2025
Yo tengo el mismo problema hace 2 días y ya reinicie , pueden por favor enviarme los detalles con los pasos a seguir para que vuelva a funcionar?
sagasmed
What if you already factoryreset your device?
Set you phones date back to before the 8th
Part_time_pig
When is this fix going to be ready? My device stopped working 2 days ago.  The amount of information available on this issue is shocking - I had already factory reset my device by the time I found any guidance at all from Google about this issue. Had previously considered upgrading to your new streaming device but will likely be buying from a competitor now.
Manually set the date on your device back to before 9th March. You should be able to setup your chromecast back to normal, before you did the factory reset.
You still won't be able to cast anything... you'll have to wait for the Google update to find out what to do next.
Don't forget to set the date back to normal once you have reconnected.
Dipkingen
Any news about this issue?
Alicia-81
Buen día, si  restableció de fabrica... Porque pensé que era un problema del Chromecast.
SaRi1907
How long is your target to fix it? I hv already reset the device 🙄
shortbals
How long will this take to correct? I have everything google, including 3 pixel cell phones. I am a loyal Google customer and have many many products in my house. I use my Chromecast audio in two different rooms almost daily. I need music in my life, when I am cooking dinner or outside washing cars or in my workshop tinkering. I have older high end speakers that tiny speakers will never replace. I need these to work.
Erasmus
Problem solved? Fixed?? It is 2 days or more so far. Inform us please!!
Zoumbacafew1203
Vous pensez que ca va etre réparé avant ce soir ?
Snez37
So the problem is not on my end ? Good to know . My grandchild really needs her tv in the morning. Hopefully it’s fixed soon.
ElenaSask
Thank you I have the same issue and already did a factory reset before checking on your website.
DaveCopas
What if you have already tried a factory reset because the issue had not been publicised?
alebensadon
Any News?
Excellent instructions for a workaround that will restore Gen2 casting from an Android device, even if you've already done a factory reset. Worked for me. Good enough, until Google issues a proper security certificate fix.
Good stuff! Just tried that and I'm able to cast again! Thank you!
Thanks much. I can able to stream now.
Ha9
Looking forward for your instructions to set it back unfortunately I reset it to factory settings since ı changed wifi device
Craftyhan
Hi, Australia here, this is a pretty poor effort from Google. No notification has gone out. An email to my google account of the issue would have been nice. I have been working on this issue since yesterday. Nothing came up in any searches of a current issue till I found this on 11/3/2025, 11.47pm for me. I have waisted so much time trying to fix this issue to find out now, it's not me, it's you Google. The Chromecast's are registered to google accounts more should have been done to get the message out. You have our details use them.
micmicmic
We have the same problem since Sunday. Nothing is working. We spent hours to try to fix reset etc., but still the same answer We couldn't authenticate your Chromecast.
What will GOOGLE do??????
slawomir1
too late. Reset done
