Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-11-2025 02:34 PM
A mi me pasa igual. Hablan de un problema en los antiguos equipos.
Entiendo que serán rumores
03-11-2025 03:07 PM
in the future
03-11-2025 03:06 PM
Still waiting for how to get my 2nd generation Chromecast to work after the factory reset. Any news?
03-11-2025 02:37 PM
My Chromecast stopped working two days ago and now when I try to reconnect it says that my device cant authenticate my Chromecast. I've rebooted and reset everything but still no connection, can someone please let me know when this issue will be fixe...
03-11-2025 02:40 PM
Exactly the same issue here. Mine has been working fine, I went away for the weekend and now it won't connect or authenticate my Chromecast. I've removed it from the home app and rebooted it, unplugged it for a few mins and tried reinstalling but I have the same error message.
03-11-2025 02:54 PM
Me acabo de dar cuenta y tengo el mismo problema incluso intenté lo mismo pero no da más que que "ocurrio un error al momento de autentificar"
03-11-2025 02:56 PM
Same Issues here, worked perfect on March 8th, stopped working March 9th with excacle the same authenticate issue.
Please help
03-11-2025 03:29 PM
Changez la date de votre téléphone au 7 mars. Ne pas réinitialiser le chromecast sinon il faut attendre le correctif.
03-11-2025 03:35 PM
Hay aplicaciones que no funcionan sin la fecha correcta
03-11-2025 03:07 PM
Estou com o mesmo problema
03-11-2025 03:10 PM
igual a milhoes de clientes roubados
03-11-2025 03:09 PM
A tech giant without respect for his customers.
A little update every hour would be a minimum after making such a big mistake.
But who are we? We are only the people that buy your devices.
Unnecessary too treat us with a little respect and dignity.
Don't cry if sales is down on your next devices.
03-11-2025 03:12 PM
they are even worst, I tried to find support, they redirected here. They put us in an empty room crying to each other , we are alone here, they are evil genious
03-11-2025 01:53 PM
Hi all, I have nothing to do with Chromecast. And I am in the some boat as you all are with it not working and have no fixes what so ever. Google nest said they were going to look into Its been 24 hrs, and they haven’t updated the community yet on a fix, it’s very frustrating and I use mine for everything, if it is the just the certificates been outdated surely that an easy one to fix, keeping figure crossed for a speedy solution 😁
03-11-2025 12:56 PM
Hello
My two Chromecast devices stopped working yesterday. I have reinstalled all devices i my Home and reconnected to hubs and routers but I cant reconnect to my Chromecast devices
please helt🙏
03-11-2025 01:36 PM
Worldwide problem. Since you factory reset (google posted to not factory reset, 24 hours after the problem started and to just wait for a fix from them) you can reconnect by setting your phone's date to a date before march 9th (march 8th or previous) then normal setup, then once connected reset to the correct date. You still won't be able to actually cast before Google fixes the problem though
03-11-2025 01:09 PM
Aparece un error al conectar, no está funcionando
03-11-2025 01:17 PM
J'ai le même problème que vous depuis hier.
03-11-2025 12:23 PM
I've used Chromecast to connect laptop to TV screen for years. Yesterday I couldn't cast tab or screen with msg ' available for specific video sites' showing on laptop where I select cast .Like everyone I rebooted , reset , panicked because couldn't reconnect...set phone date before 8/3 and was able to reconnect ..phew...but obviously not being able to cast still. However ..my question is ..does anyone else have same msg ..?
03-11-2025 03:13 PM
there is nobody from google here, we are alone crying to each other
03-11-2025 01:14 PM
Just adding another complaint regarding chromecast 2nd gens not working. Way-to-go Google!! Great job on this slip. Please advise of a fix asap.
03-11-2025 04:19 AM
2 giorni che non funziona..perfavore potete fare qualcosa
03-11-2025 03:37 AM
No consigo conectar chromecast y tras hablar con un técnico me ha dicho que escriba aquí para recibir actualizaciones de la reparación. Espero que sea pronto. Ya tardan demasiado.
03-11-2025 03:17 PM
es mentira, aqui es una sala vacia, solo clientes
03-11-2025 03:15 PM
"Don't factory reset"! But that's exactly what your trouble shooting guides say to do. Do better google.
03-11-2025 03:18 PM
this is an empty room, they put us here alone
03-11-2025 01:51 PM
Still waiting for Google to fix the problem. It's not connecting and I'm getting the message that Google can't authenicate my Chromcast! This is going on since 2 days already! Please 🙏 help!
03-11-2025 01:58 PM
Same issue just occurred for me (11th march 2025) and I have happily been using the Chromecast audio device everyday for years never having this issue
03-11-2025 01:59 PM
I have the same problem with 2 differents chromecast! 😡
03-11-2025 02:03 PM
Même souci, problème de chez Google apparemment... Je viens de réussir à reconnecter en modifiant la date de mon téléphone au 1er mars. Avec l appli canal, j arrive à caster, mais c est tout
03-11-2025 03:00 PM
Pourquoi changer la date du téléphone ? J'ai le même problème aussi depuis le début du wknd.
03-11-2025 03:10 PM
J ai cru comprendre à un problème technique Google SSL depuis le 8 Mars qui fait que les chromecast n accèdent plus à internet. Au 7 ça devrait marcher j ai mis le 1er pour prendre de la marge.. Et j ai réussi a les reconnecter.. Il faut attendre une mise à jour qui est sencé arriver rapidement
03-11-2025 02:37 PM
Same issue for me since yesterday (March 10th 2025)
03-11-2025 02:39 PM
Same issue for me since 10th March 25, saying it can't authenticate, have never had an issue for years! What's going on how do we fix it?
03-11-2025 03:20 PM
Hola, sigue sin funcionar
03-11-2025 04:47 AM
Al cambiar mi tv de habitación sin realizar ningún cambio ni en la tv ni en el chrome, de pronto dejo de funcionar, por légica intente solucionarlo y al final como se hace en todos los casos empiezas de nuevo lo reestableces valores de fabrica y te lo configuras como tu quieras. Harto me decís que no tendría que haber restablecido los valores de fabrica. Eso me suena a escusa para nos demos por amortizados. es decir la culpa es tuya por seguir las indicaciones lógicas de cualquier técnico para cualquier equipo. Excepto para vosotros. Esto tiene solución lo que pasa es que no tenéis ganas y dentro de poco mandareis ofertas de Chormecast de ultima generación y a facturar.
03-11-2025 03:22 PM
Ya lo restaure ... Que hago ??
03-11-2025 03:23 PM
It is ridiculous that this is still an on going issue with no further updates or statements
03-11-2025 02:04 PM
Ciao a tutti,
ormai da giorni non riesco a collegarmi a Chromecast. Vedo solo ora che c'è un problema a causa di un certificato SSL scaduto.
Ci sono informazioni sulle tempistiche di risoluzione?
03-11-2025 02:27 PM
Sono nella stessa condizione, ho provato di tutto
