GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,131 REPLIES 16,131
Kindly provide an ETA on this, please
Is there any compensation for several days not being able to use the products, please ?
Thank you !
And if we already factory reset b.c this has always been the first step in troubleshooting issues with gen2?
This is not acceptable Google, AI responses and no information...
LAST UPDATE
No solution provided is working It is does not work Disconnects Sorry guys I sang victory too soon Apologies
Going to use a non Chromecast device That's the SOLUTION
https://mensfeld.pl/2025/03/bringing-your-chromecast-back/#how-to-fix-it
I have 4 of these driving ceiling speakers throughout my house. Please fix 🙏
I am one of those. Please contact me as soon as possible. Or I Will look for a different model to solve this
I removed my device from Google Home. I can't add it back again. How will I know when a fix has been done and what to do? Will I get an email or text? How long will the fix take?
Ronaldo13
Mude a data de seu telefone para antes do dia 9 de março, dia 7 por exemplo. Isso fará com que consiga sair do reset de fábrica mas ainda assim não vai conseguir transmitir a tela
Im sure we all agree on the fact that WE NEED AN ETA
Toujours pas réparé ?
I have three of the audio devices but won't move forward on anything because I am sceptical as to whether we'll get a fix this side of Christmas. I truly and say again I truly hope I am very wrong and it is actually being fixed and will have a resolution soon rather than 2027.
I have noted that The pixel 9 has dropped in price again plus there's a whole interesting idea on discounts on Chromecast devices the newer ones.
I'd have absolute rocks in my brains which isn't far off anyway but who in their right mind would buy something when it's broken?
Devices need an email address, you could send a mail to explain what is happened, and happening, instead leaving people loosing time trying to reconnect devices and to contact you!!!
Following
reading all these comment of those affected is both hilarious and sad
How much longer until it is fixed and will you let us know when this is done please
What if I did a factory reset before reading this?
Por favor mantenme al tanto de la situación. Esperamos que se solucione pronto
Where will the fix be announced?
And how is it progressing?
it is a chat room, not support
Una pena que haya ya restablecido valores de fábrica. Espero que lo solucionéis pronto y ofrezcáis algo más que unas disculpas.
Cuando lo compre no me ofrecieron ningún descuento  o rebaja por estos daños ocultos que iban a aparecer!!
It'a shame! Im having same problem. My chromecast will not work , keeps saying Unable to authenticate. How much longer until problem will be fixed?
You are a world wide company - reaching out to the whole world. It should not take more than a day to fix this. It is really bad costumer service you are in the midst of. Not doing an official note in medias, Facebook or X. So we didn't have to roam the darkest web to find out what is going on. Meanwhile you are taking forever to fix it!
worst. they put you not with support but in an empty community room.with us, other customers LOL
Chrisbear
You are experiencing Google Customer Support at its finest. I gave up after two years trying to buy an extra mounting ring for my Google Nest fire alarm!!! They don't even have a phone number... at least you can ring Microsoft !
First rule of your troubleshooting guide : factory reset your device 🙄
What happens to the ones that factory reset? Will they br able to restart the device once the fix is available?
Metti la data del cellulare al 7 marzo e istalla .Non funziona uguale ma e' pronto per un nuovo aggiornamento
Dear Support Team,
Since last Sunday, I have been experiencing issues with my Chromecast, rendering it unusable. I was informed by support that the issue would be resolved within 48 hours; however, I have not received any updates so far.
At the time, I performed a Factory Reset, as there was no prior notice indicating that this should not be done. I would appreciate a response regarding when the issue will be resolved and what steps I should follow to make the device work properly again.
I look forward to your prompt response.
Gustavo
gustavo, they are not here , they are so nasty that they redirected is to an empty room, nobody is listening you
Chrisbear
Chromecast Gen2 sales are estimated to be in the tens of millions. Going to be a lot of notifications in my Inbox by the end of the week !
I had 720 this morning 😕
I factory reset before this info came to light. I will be very interested in a fix for this as other streaming devices don't do what this does.
PANORMUS
Metti la data del cellulare al 7 marzo e istalla .Non funziona uguale ma ' pronto per un nuovo aggiornamento
I first consulted the help via the Google Home app. There I was advised to reset the Chromecast to factory settings. After further Googling I ended up on this site. It's nice to read here that it's a global problem, but I keep reading that you shouldn't do that, too late. In the follow-up message from Google I also read that it's possible that the Chromecast can't be started at all after resetting to factory settings. That would be really bizarre Hopefully there will be a solution soon. And I can use my Chromecast again..
So when will this fix be available ? I now have 2 not able to authenticate devices ....
I did a reboot of my device because i didn't knew that there was a problem with the device, Can you inform me what to next if the problem is fixed please?
How many days it will take. Atleast give any update. Use help of AI. Take quantum chip help. Sundhar Pichai. Please help here.
This sucks… do not factory resert the device!!! Ok thank you 😡
yo lo resetee sin saber qué hacer, Como lo resuevo?
Please, I want to use my device! I already reset it because I was unaware of this issue.
