GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
Any fix yet? And what do we do if we did a factory reset?
Ainda não corrigiram essas atualização? Já estamos a dias sem poder usar um aparelho que custou caro.
This has been going on for days now; either Google wants to sunset the original Chromecast devices, or they are not competent to fix the issue.
Tired of waiting ordered this from Amazon to take Google out of the equation: https://www.amazon.com/dp/B0D6R3XT17?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
When will this be fixed please?
Yep. Step 1 in troubleshooting is turn it off and back on. When that doesn't work, factory reset. I guess I'm in that camp so I'll need the instructions for someone who factory reset their device.
Please share an little howto fix cert issue. Thanks.
Why 4 hrs ago I was told by google to factory reset my chromecast??  What a farce if you don't get a new patchwork ore whatever can I get my money back ?? It was sold to me with a certainti that the chromecast will get updates if necessary also patches and what not to operate smoothly in the future.   Should buy a Google telephone at coming Monday but I think I will go for a samsung again.. Maybe a Trump issue????
Van a tener algún tiempo estimado de solución?? Tengo tanto el de 3° generación como el de 2° sin funcionar desde el domingo.
Gracias
When is the resolution rolling out? And google never told me by email??
I’ve been tweeting about this so I really appreciate the responseI I have to watch it on my Chromebook, but well, we all have to make allowances at sometime
Google owns the information of nearly half humanity, one of the biggest companies on earth, takes 3 business days to solve an issue on Chromecast devices worldwide....
Não estou conseguindo conectar
Hi Google nest Team.  I appreciate this is likely a complex resolution path.  But when are you expecting to make a patch available.?
Hola, no tenía esta información y restableci mi chromecast quedo muy atenta, mil gracias! #
Hello, any updates?
... Mientras tanto que se puede hacer?
I need to change my wifi as i got a new router?
Pero lo que tenemos el dispositivo viejo, si va funcionar?
Update please... It is the least you could do - esp. since the problem was caused by either poor records and/or poor change management.
Reiniciei um aparelho os demais estão corretor.
Gente resolve logo este problema sério que falta de respeito.
Any update??
Cómo es posible comprar y confiar en un producto y que pase esto. No salió barato en su momento..
FIX the PROBLEM!
How much longer…. Our use is disabled till fix.?
Any ETA on the fix??
Hurry the **bleep** up and fix this massive oversight. I can't even go out and get the Chromecast with Google TV because there is no stock! You guys are the new Tesla, pathetic
Meu Chromecast não está autenticando. Sempre aparece a msg de "Não foi possível autenticar seu Chromecast" o que devo fazer?
Yo esta tarde he reiniciado a fabrica y ahora no es posible hacer nada con el, me gustaría que me ayudaran para poder arreglarlo, muchas gracias
Lo reinicie y ahora no lo puedo configurar
Any update for today??
Is not working yet!! I just read tha post, and I already factory reset the device before
Vamos ter reembolso?
I reset the device. How can I fix it?
Qual seria o prazo de regularização do sistema do Chromecast ?  Ou terei que adquirir de outro fabricante? Por favor, estou sem tv.  Uso o Chromecast para ter acesso a minha tv
Espero que solucionem e q me avisem no email ok
Pero tienen una fecha límite para solucionar? Necesitamos tener una respuesta más clara y medible
I have already done a factory reset.  Please advise
My Chromecast was working working great until last week and will not connect! Please fix soon thanks.
It's been days now of being unable to use my Chromecast and therefore my TV, as everything runs through my Chromecast. When will there be an update to fix those who followed the troubleshooting and reset their Chromecasts??
