Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-13-2025 04:51 AM
Já se passaram 5 dias e ainda nada do cromecast 2 voltar ?
03-13-2025 04:52 AM
did reset!
03-13-2025 04:53 AM
When will it be fixed or should we look towards buying others product for streaming.
Any update would be beneficial, sure someone from the team is monitoring all these comments.
03-13-2025 04:53 AM
どのようにすれば解決できますか? 早くクロムキャストでNetflixが観たいです。
03-13-2025 04:57 AM
Any update, it is two days later...
03-13-2025 04:57 AM
Hello Google. Another day goes by with no more information from you guys. What kind of customer service is this?
03-13-2025 04:56 AM
La paciencia tiene un límite.
Tiene idea aproximada de la fecha en que este problema de solucionará?
Y sería importante que además de decir que están tratando de solucionarlo lo antes posible, mantengan mayor comunicación sobre el tema
03-13-2025 04:59 AM
Please hurry on this issue I am unable to connect to Chromecast this is ridiculous I haven't been able to watch TV for days. When is this going to be fixed.
03-13-2025 05:03 AM
In the meantime i lost my patience.....
03-13-2025 06:24 AM
03-13-2025 05:03 AM
I did a factory reset, can you send instructions to reconfigure it, thanks
03-13-2025 05:05 AM
Please inform me directly when fixed
03-13-2025 05:08 AM
Is this why the groups I, like speaker groups,light groups etc i've created in Home, disappeared and don't work?
03-13-2025 05:09 AM
When??? Starting to get really annoyed now.
03-13-2025 05:10 AM
Si ok, ma in questo momento non posso usare il Chromecast . Purtroppo ho resettato il dispositivo. Sto cercando di configurarlo ma non riesco ...risolvete
03-13-2025 05:12 AM
Vergognoso. Pessimo servizio. Come si poteva non saperlo.
03-13-2025 05:12 AM
Screw this…. You guys took way too long. I already switched over to an amazon fire stick for my streaming needs. You can’t have multiple days of outages and expect people to sit around waiting when there’s multiple different companies offering the same services.
03-13-2025 05:14 AM
It's been 4 days now, any updates on when this will be resolved?!?!
03-13-2025 05:15 AM
lo reseteé dos veces porque era lo que el servicio de ayuda me decía que hiciera 🙄
03-13-2025 05:19 AM
This is disappointing. Please work on this ASAP. I also wasting money on Netflix and Disney subscriptions when I can't even use it on our TV
03-13-2025 05:21 AM
Can we get an update on the timeline for a fix for the Chromecast 2nd Gen problem please?
Many thanks. Dave Hughes UK
03-13-2025 05:23 AM
How long yet???
03-13-2025 05:26 AM
This is the work around. You will be able to cast after following these steps!!
03-13-2025 05:28 AM
Is there an update on the timeline for the fix to this issue please? How do you intend to communicate it?
03-13-2025 05:29 AM
When we will get fix on 2nd gen Chromecast? Please update, we trust you and bought google product.
03-13-2025 05:29 AM
Has there been a fix for this issue? I reset my device as it was one of the first steps I took based on their troubleshooting guide
would love to get my Chromecast working again please 🙏
03-13-2025 06:28 AM
Look my answer up to Angelina 1 34 min ago she asked the same I gave the answer
03-13-2025 05:32 AM
Thank you for the information and awaiting a replacement product to be sent or updated certificates to be installed (if even possible)
thank you
03-13-2025 05:33 AM
How are you to inform us about coming steps ?
03-13-2025 05:33 AM
This is so rude. It is Thursday and no update from Google community Manager. Milions od devices still not working. Are you serious?
03-13-2025 05:36 AM
リセットしましたが
03-13-2025 05:39 AM
Hola soy Monica.Necesito una solucion..lo restableci ,ya que todo el mundo recomienda eso.andaba perfecto hasta el.domingo 9/3.Busquen una solucion ya que no es justo.Ayer compre uno nuevo(carisimo)4ta generacion con control..y mi tele al ser plasma y que debe enfufarse atras no lo registra.Una verguenza por parte de google.en led que se conecta del costado si funciona. Nevesito una respuesta y solucion para el 3ra generacion.Gracias
03-13-2025 05:48 AM
I have already factory reset my device. What should I do?
03-13-2025 06:23 AM
Doesn't matter, if it is a certificate expiration we have to wait for a possible fix.
03-13-2025 06:26 AM
Switch of auto date and time of choose a date before the problem like 5 March and the home app will reconise your chromecast etc again... after it you still can't cast but you can look at the pictures again it's better then a black screen and first part of the problem is solved .. you can set auto date / time back on when your chromecast is installed again 😉👍
03-13-2025 05:52 AM
Are you paid, to delay your 2 gen update, how looog will it take, get on this issue and fix it, as we all other workers have to do every day 🙄🥱🙃
03-13-2025 05:56 AM
Vários usuários foram prejudicados e nenhum prazo foi dado pra essa atualização. Espero que reparem o quanto antes este problema!
03-13-2025 05:59 AM
Just seen an article quoting a former meta employee that a solution could take weeks. Is this true GoogleNestTeam? Also, not all of us received your email that’s been published in the news.
03-13-2025 06:06 AM
All the email said was basically to keep an eye on this Google Nest Community page. So you're already in the right place. Any updated information will be posted and pinned to the top of this page.
03-13-2025 06:12 AM
Mi sembri uno dei più esperti per cui mi permetto di chiederti ma a tuo parere quanto tempo ci potrebbe volere perché impiantino una soluzione che rimetta la situazione in funzione? Grazie
