Volume increases by 2 points
Drio
Often the volume changes by increments of 2. If i click really fast on the remote control button it increments by 1. The other buttons does not behave like this.
I have a Philips 75" PUS8500.
In Google TV streamer settings the remote buttons Volume control is set to Philips TV (IR) because Auto (CEC) is not working.
See video of the issue: https://youtube.com/shorts/gc5v5sz2afk?si=hJeRWEMGbdw7ggXI
moralesvicente
Hello @Drio
Thank you for reaching out to the community. I understand you’re experiencing an issue where your Google TV Streamer Voice Remote increments the volume by two points at a time unless you click the button very rapidly. No worries; it’s a pleasure to assist you.
I appreciate you sharing these details with me. To isolate the cause, please perform the following steps:
  • Remove the batteries for at least 10 seconds, then reinsert them, and check if the issue persists.
  • Try using new AAA batteries.
  • Unplug the USB-C cable from the streaming device. Leave it unplugged for one minute, then plug it back in.
  • Reset the Voice Remote. For detailed instructions, please refer to the guide: Factory reset your Chromecast or Google TV Streamer Voice Remote.
Please let me know if these steps resolve the issue or if you need further assistance.
Daniel
i have tried the steps above which is:
- remove remote AAA batteries for 10s and use new ones
- unplug usb-c cable for 1min from google tv streamer
- reset voice remote to factory settings
there have been no changed behaviour after this and the same issue persist.
i have now instead changed Volume control settings from Philips TV (IR) to Google TV Streamer. This makes the volume to increment by 1 points correctly.
The drawback is that i sometime need to use the philips tv remove to control the volume as its not synced by google tv streamer.
moralesvicente
Hey @Drio
Thanks for getting back to me and sharing this information. To continue addressing the issue, please follow these next steps:
  • Can you please try to use your Google TV Streamer with a different TV and check if the behavior continues?
Let me know how it goes.
Daniel
