02-04-2025 01:28 PM
Hello. I use chromecast at home. My wifi network is 5 ghz. Channel in use is 38.
Chromecast connect with high speed like 250 300 mbps,then speed goes down all the way to 8 mbps or 12 mbps.I check it on the wifi router.
Solution is restart.
All other devices work fine-phones, android tv,notebook. Chromecast is 1 meter away from wifi router.
02-04-2025 01:30 PM
P.s. I tried factory reset,no luck.
02-07-2025 02:07 PM
Hi @Aloen287!
Thank you for posting in the community. I'm sorry to hear that your Chromecast is not consistently getting full internet speed. I appreciate your efforts in taking those steps before. I'm happy to help you!
To help me find the best solution, I'll need to ask you a few questions:
Please keep me posted. I'll be waiting for your response.
Geremi
02-07-2025 02:41 PM
1.Chromecast 4g.
2.the question is about wifi 5g,of course it connected wirelessly
3. Different times different apps
4.which image? Sometimes it happens when I am not casting
5. I checked on 4 routers. Cisco,compal,linksys and tplink
Chromecast up to date
02-07-2025 08:20 PM - edited 02-07-2025 08:21 PM
Hi @Aloen287!
Thank you for your response. Let's work together for a solution. To best assist you, I would like to ask some diagnostic questions to identify the root of the problem you are experiencing. These steps will help us isolate the issue and find a faster solution.
Thanks for your kind attention; I will be looking forward to your answer.
Geremi
02-07-2025 11:48 PM
1. Chromecast with google tv
2.no changes to router. I noticed fee mnth ago. Before that bot sure,maybe I was just reliading it but not checked speed
3.no messages when im not running any apps or video
4.when watching youtube for ex,it is trying to open but nothing comes to screen
02-08-2025 06:02 PM
Hi @Aloen287!
Thank you for the details provided. I understand your concern about the internet speed your Chromecast with Google TV is receiving. Since you mention that you don't experience performance issues like buffering, lagging, or the video not playing properly, it's possible that the reading from your router indicates the bandwidth your Chromecast device is using at that specific moment.
If you have a Chromecast with Google TV (4K), for smooth, high-quality 4K streaming, we recommend an internet speed of at least 20 Mbps. This will allow your Chromecast to run smoothly and give you the best possible image quality.
If your device is a Chromecast with Google TV (HD), the internet speed requirements are lower, as high-definition streaming consumes fewer resources than 4K streaming.
It's important to remember that your Chromecast will not use all the available speed from your router. It only needs enough bandwidth to efficiently stream content, whether in 4K or HD.
Geremi
02-08-2025 11:49 PM
But I wrote that on low speed like 9 mbps youtube is not opening. So there is performance issue .
