Accidently removed cameras
aklint
I accidently removed my two outdoor cameras, can I reset it?  The are located outdoors high up, so getting the QR code or numbers will be very difficult
Rubes
You can set them up with either the codes on the camera itself or if you have the original packaging, the QR code is in the box.
aklint
I do not have the original packaging.  So I guess the only way is grab a ladder and climb up to get the QR code.  Is there anyway to reset the history to a certain time...then they should come back?
I apologize for my late response. Thank you for all of your patience while waiting for a reply. I can definitely understand how frustrating your situation must be. I just wanted to make sure that your issue is addressed.
  • Do you still need help with this issue?
  • What other troubleshooting steps have you done thus far?
Eric_B
Hey aklint,
Have a great day!
Eric
Jeff
Hi, everyone.
Thanks
