Add Starter Motion for Wired 2Gen Doorbell and SmartThings integration
mcdemarcay
It is great that the updated Google Home app added Routine Starter options, but the only one for the Doorbell is "Doorbell Rings". Does anyone know if there is a plan to add "Doorbell Motion" as a potential starter. It would be nice to have a Routine that turns on the porch light before the person trips up the porch to go press the doorbell.  I know I could add another motion sensor, but it would be nice to utilize the built in motion on the doorbell.
Also, allow motion from doorbell to be used in SmartThings.  It doesn't look like it is integrated with SmartThings yet. Under Google Partner Connections setup for Samsung SmartThings it only shows Outdoor Camera and Thermostat options, no Doorbell yet. Looking at it from SmartThings app side, same camera and t-stats.
Sorry to hear the feature you're looking for isn't an option. We’re always looking for ways to improve, and appreciate your feedback. You can send it at any time using your devices by saying, "Hey Google, send feedback," or by following the steps found here
janthadeus
Checking in should you still have further questions here. Let us know by replying to this thread.
I appreciate the help here, Brad.
janthadeus
