Battery doorbell
Fedup
Disappointing to note wired connection with doorbell is not compatible with European chimes which are standardized to run on 8v ac. It is almost impossible to find a chime in the UK that runs 18v ac hence my chime  does not work. I think Google should have researched this before releasing the doorbell. Documentation is not clear. I have had to buy more equipment just to find out who is at the door.
2 REPLIES 2
Sorry for my late response. Thank you for all of your patience while waiting for a reply. I just wanted to make sure that your issue is addressed. I can definitely understand how frustrating your situation must be. I would love to help you find a solution to this issue.
  • Do you still need help with this issue?
  • What troubleshooting steps have you done thus far?
Fedup
Thanks for your generic response Brad. I don't think you actually read my post.
