Camera going offline after power outages
6734
Camera going offline after power outages  - nest outdoor cam gen 1 these cameras have a known problem coming back online after power outages  and its not just one of the cameras its pretty much all of them its a miracle when one of them makes it back online after a power outage and it appears  google uses bots to responds to customer posts about this because there's no solution other than do without your security cameras until the ice melts and you can get your ladder and get 20' feet in the air to unplug it and plug back in how primitive is that for a technology company seeing how this problem has been going on for over a year it appears no solutions in site we as their customers should make it known by going and producing some negative reviews so others don't waste their time and money with these expensive trash cameras.
dB121
You are right it's a huge problem with these cameras. We have a lot of power outages in our area. I have brought the cameras inside for set up. Only to return them back to the original spot. Message i receive over & over is something went wrong try again. The latest out door camera doesn't even have a status light? I have tested the outlet & there is no problem with this connection. I recently bought several ring cameras( battery operated) they connect & connect flawlessly. I much prefer nest video quality over rings. But at least i get a notification.
janthadeus
Thanks for the help, Brad.
janthadeus
6734
Ok So, I tried something and it work me if you have a power outage and they don't come back on line if you know your breaker flip it off wait ten seconds and flip it back on, its worked twice for me . Good luck
