Camera won't record more than 3-5 seconds
Dannylrios
My camera (outdoor plugged in) won't record more than 3-5 seconds. I changed the settings to max 3 minutes and put the battery option to highest but still only get 3-5 seconds. What could it be?  Thanks!
10 REPLIES 10
I apologize for my late response and thank you for all of your patience while waiting for a reply. I understand how frustrating your situation must be, and I would love to help however I can. I would suggest updating your settings to match what you want to be recorded. It could be that the events being recorded are only that small. The newer 2021 devices are event-based recording devices only.
aatienza
Hey Dannylrios,
Appreciate the help, Brad. I just wanted to follow up and see if you're still in need of help. Please let us know as we would be happy to answer any questions you may have.
Archie
aatienza
Hey Dannylrios,
Archie
Hello, I just realized that I have responded to the email instead of here. Well, I can't seem to make it record more than a few seconds. I tried changing the battery option and changed the video option to record for 3 minutes but it keeps recording a few seconds. Videos are just stopped or cut off. The doorbell works just fine. This only happens to both of my nest battery cameras (they are plugged in 24/7)
aatienza
Hey Dannylrios,
Understood. To confirm, do you have an active Nest Aware subscription? If so, could you tell us the type of Nest Aware you have (new Nest aware, Nest Aware Plus)?
Archie
Just regular nest aware
@Dannylrios
Which Plan do you have? We would like to know the specific if you can!
SteveT1
Checking back in should you still need our help here. Let us know by providing the requested information above. I would also recommend to check if your Nest Cam (battery) is added on the home with the Nest Aware subscription.
Steve
Jeran
Hey there Dannylrios,
Did you have any more questions or need any additional help?
Thank you,
Jeran
Jeran
Hey Dannylrios,
Just checking up,
Jeran
