Como activo mi camara
Ubaldo16
A pesar que le pongo el password de la parte [posterior no me hace válido y no puedo activarle el producto me ayudan por favor
David_K
First let's check, what model of camera is it?
Technical specs for Nest cameras and doorbells - Google Nest Help
I see you selected Nest Cam Indoor when creating your post, which is setup using the Nest app, not Google Home app. Please make sure you're using the correct app. Are you following the steps underneath "Nest app" in the help article below?
Set up and connect Nest camera - Google Nest Help
The app walks you through the setup. The camera has a QR code on the back. Scan the QR code on the back of your camera. You can also tap "continue without scanning" in the app and type the numbers at the top of the QR code.
Juni
Appreciate the help, davidking.
Ubaldo16, thanks for reaching out. I hope you've got the answer you're looking for. If you're still in need of assistance, please let us know, as we would be happy to answer any questions you may have.
Juni
janthadeus
Hey Ubaldo16,
I appreciate the help here, davidking and Juni.
janthadeus
