12-07-2022 01:59 PM
Unfortunately I live in cold climate and it my Nest Cam with floodlight (wired) is showing offline because of extreme temperature.
My question is will the device come back online by itself once the temperature improves or will I need to reset in manually?
12-07-2022 02:58 PM
Yes it will come back online. I bought one last year and went through a winter with it. When the temp dropped it went offline and it came back everytime. Depending on the temp you will just have to be patient, unfortunately.
12-19-2022 04:21 PM
I appreciate your help, MplsCustomer, James11 and Brad.
12-07-2022 03:16 PM
We have what is basically the same camera, the Google Nest Camera (Battery) (plugged in) and it remained online during the last Minnesota winter at temperatures down to -20 degrees Fahrenheit.
The operating temperature for both cameras is: -4°F to 104°F (-20°C to 40°C)
Ours is helped slightly because it's mounted on the house and under a camera shade.
12-07-2022 03:27 PM
Living in Winnipeg Canada and it was -25F last night
Here's hoping it doesn't happen to often
12-13-2022 10:54 AM
Thank you for your patience, and sorry to hear that you're experiencing this. I know that keeping your Nest devices charged is very important, and I would love to help you out. When it comes to keeping your Nest Doorbell (battery) or Nest Cam (battery) up and running, here are some articles and troubleshooting guides for the best charging practices:
I hope those articles help shed some light on charging and maintaining battery levels of your Nest doorbell or camera. Please let me know if you need further assistance.
12-13-2022 11:03 AM
Winnipeg experienced on average 60 days per year at -18C or below in the last decade. Would a thermal blanket help or does the camera turn off when Google detects -20 or below from a central source? Can we override this behaviour? Can we mitigate the cold to keep it from turning off?
12-13-2022 11:36 AM
I am afraid this is not something that you can override. It's pretty inherent in most, if not all, lithium batteries in wireless devices. Colder weather is always going to affect battery life. You can lower your sensitivities if you wish, which has been known to help some users, but as long as it is in a colder environment, the battery may drain a bit more regularly.
12-16-2022 01:17 PM
12-21-2022 05:20 PM
Live in Winnipeg also and battery powered ( plugged in) camera goes offline meanwhile older cameras ( wired ) and a door bell work flawlessly.
12-21-2022 05:28 PM
This is Google Nest's help page on cold weather battery charging behavior. We live in Minnesota about 400 miles south of you, and have had the battery camera plugged in for 15 months; it's always "Live" but the coldest it's gotten so far is -20 degrees Fahrenheit (last winter). We've had wired doorbells and cameras for as long as 3-1/2 years and so far none have gone out due to weather.
12-22-2022 04:13 PM
I understand that this week is pretty cold but my 3 week old outdoor camera is offline and has been since -5ish fahrenheit. It has been plugged in the whole time. So are these cameras useless in Minnesota? I was working on switching completely from Ring but all of my Ring floodlight cameras are working and have never turned off due to cold weather. I understand why it wouldn't work if it was only on battery but I never plan on unplugging it... Did I make a mistake?
12-23-2022 06:01 AM
We've had a Google Nest Camera (Battery) for 15 months, plugged in with the optional 19-meter power cable, and it's stayed online and "Live" continuously, at temperatures as low as -20 degrees Fahrenheit last winter in Minnesota. It's -11 degree Fahrenheit right now. We have the camera mounted under a camera shade that gives it a little shelter.
Are you using the included 3-meter charging cord or the 5-meter or 10-meter power cable? Is your cable/cord plugged in so that it feeds towards the FRONT of the camera? When your camera is online, does it show as "Live" all the time? Under Settings | Battery, does it show as "Plugged in" with an infinity symbol? Did you get an extreme temperature message, or did the camera just go offline with no warning message? (If it's the latter, it could be due to Wi-Fi signal strength and not temperature.)
I've seen posts in this forum where the cord was plugged in incorrectly, or the USB plug was defective, or the 3-meter charging cord was defective.
12-24-2022 07:16 PM
Using the cord that came with it and the battery menu shows that it's plugged in. I have it mounted under part of our roof so it somewhat sheltered as well. I never received any weak wifi notice and it just went offline without any warning due to extreme temperatures. I appreciate your reply but everything seems to point to it just being too cold 🤷
01-08-2023 06:01 PM
Hi SedlerFam,
I'm sorry for the delay. Could you bring your camera inside the house and check if it's going to reconnect to your Wi-Fi network?
01-12-2023 02:11 PM
Hello there,
I appreciate the help, everyone.
Archie
12-24-2022 06:30 PM
Checking in — we hope MplsCustomer’s response answers your questions. Let us know if you have more questions in mind.
Thanks for the help here, MplsCustomer, Brad and Emerson.
01-15-2023 03:39 PM
Hey Craig_wpg,
Nice! Sounds like a plan. Keep us posted.
Thanks for chiming in, Archie.
01-18-2023 04:32 PM
How's it going? Still need our help?
01-18-2023 08:32 PM
Once it warmed up it came back online. I really feel like there needs to be a way for the camera to stay online if it's plugged in. I understand if it needs to protect to battery in cold temperatures but why shut off completely when it's too cold? The doorbell stayed working... And all my Ring Floodlights, which I was going to replace with the Nest ones but am second guessing that choice.
01-19-2023 10:26 AM
Thank you for sharing your experience with us. I understand that it may be an inconvenience, but it is the best way to protect the battery when it gets too cold. We’re always looking for ways to improve, and appreciate your feedback. You can send it at any time using your devices, following the steps found here.
01-22-2023 02:38 PM
I want to check if you still need help. Don't hesitate to reach back if you do.
01-23-2023 04:13 PM
Hello there,
Just checking in to make sure that you saw my response. I'll be locking this thread if I won't hear back from you again in 24 hours. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
12-07-2022 06:04 PM
Same. Is there a way to bypass this battery backup during our long cold winters? Is there a thermal blanket we can wrap around to keep the camera operating? At least the floodlight continues to work.
12-07-2022 06:30 PM
The floodlight camera runs off of household current, not off of the battery (unless the power is off). If the camera goes offline at -25 degrees Fahrenheit, it's doing so because that's below the camera's operating temperature.
We've been lucky so far with our plugged-in Google Nest Camera (Battery) at temperatures down to -20 degrees Fahrenheit, but I think it helps a little that it's tucked under a camera shade and is mounted on the side of our house. Our older cameras are mounted under our garage eave, and also stay online at those temperatures.
12-19-2022 08:11 PM
Hi. The thread remains unanswered.
Does the wired Nest Floodlight camera turn off because Google tells it it is -20C or does it 'sense' it is -20C and turn off because it is cold?
Can I cheat and tell the camera it is somewhere warmer? Another 5 degrees Celsius means the camera would remain on longer.
Thanks!
01-12-2023 05:11 PM
I am committed to finding a thermal blanket for the Google Nest Cam (wired) with Floodlights that I can wrap around to keep the camera operating below -20 Celcius. I can confirm the floodlight continues to work below that temperature, and is trigged only by motion and comes on full intensity (100%). I'll see what little doggie vest I can find online that will fit the camera's elongated body.
