12-23-2022 12:52 PM
Just got the new Google WiFi Pro and can't get the doorbell to connect. I have removed it from the app and done a factory reset. When trying to add it back, it just keeps trying to connect and it never does. It doesn't even get to the point where I can choose the new WiFi. I have a camera that easily reconnected, so I am quite frustrated.
2 weeks ago
Hey Archie,
I found another thread that solved this problem. Apparently when doing a reset on the doorbell, the reset button. Needs to be held for 30 seconds rather than the 12 that is in the instructions. Thanks for your help.
12-28-2022 07:52 PM
Hey Muleman329,
I’m sorry to hear you’re having trouble with this. No worries, we'll check this out. Could you tell us the exact message you're getting? What's the status light of your doorbell? Have you tried reinstalling the Google Home app to make sure it's up-to-date?
Archie
12-29-2022 04:11 PM
Thanks for getting back to me Archie. The message I get is "Connecting to your device" then it never connects. Then it says "make sure your device and phone are on the same network". That is the problem. It never allows me to select what network to use even after doing a factory reset. Any help will be greatly appreciated!
3 weeks ago
Hey Muleman329,
I'm sorry for the delay. What phone are you using to set up your doorbell (Android, iOS)? Could you tell us the status light of your doorbell? Are you using a dual-band router (2.4 GHz and 5 GHz)? Make sure your phone and doorbell are closer to each other. Also, turn off your mobile data while setting it up. Keep us posted.
Archie
2 weeks ago
Archie
2 weeks ago
Hey Archie,
a week ago
@Muleman329
Thank you for confirming this has ben resolved for you. We're relieved to hear this, so we'll leave this topic open for another 24 hours in case there are any follow-up questions or comments.
