07-10-2022 11:45 AM
Does my Nest doorbell have a battery that I need to replace ? I don't hear the doorbell ri g on my phone and the speaker doesn't work.
07-10-2022 12:00 PM
The Nest Doorbell Battery version does have an internal battery that needs to be charged, not replaced, you would just plug it into a usb charger until its ready.
https://support.google.com/googlenest/answer/10901611?hl=en
07-10-2022 06:36 PM
Hi FC, Asherpherdson is correct. But one thing that I thought of is are you on the older Nest HELLO doorbell and you are using the NEST app?
07-18-2022 03:38 PM
Hey Fc02861,
Appreciate the help, Ashepherdson and EmptyNester. I'm dropping by to ensure if everything is covered here. Hope that sheds some light on the issue.
Archie
07-21-2022 04:57 PM
Hey Fc02861,
Archie
07-22-2022 05:03 PM
Hey Fc02861,
Archie
