Doorbell
GQHicks24
My doorbell best battery will not connect on google home for me to finish setting it up
1 ACCEPTED SOLUTION
Ashepherdson
I'm flagging this so that a Google employee will respond directly to you, as I'm sorry to say I'm stumped as to why this is happening !
View solution in original post
23 REPLIES 23
Ashepherdson
Are you on the same wifi network? Is the signal weak?  Have you tried rebooting your router ?
GQHicks24
It’s saying it cannot connect to assisting devices. I just installed my Hub and Display Monitor without any problem. Idk about the connectivity though
Ashepherdson
Try a reboot of your router , phone, and the nest hello.   It's probably a connection issue that will be resolved with those reboots.
GQHicks24
How do I reboot the hello
Ashepherdson
  1. Locate the reset pin hole on the back of the doorbell
    Tip: The reset pin on the Nest Doorbell (battery) is located below the USB port on the back of the doorbell.
  2. Press and hold for 5 seconds.
  3. Your doorbell will restart, and the status light will be steady, solid white.
GQHicks24
I did that and it still won’t connect
Ashepherdson
And you rebooted your phone and router as well? What kind of phone is it?
 I reset my router and my phone I have an iPhone
Ashepherdson
Is the nest hello plugged in via the usb port ? Do you have any alternative device that can run the Google home app to try?
GQHicks24
Yes I have it plugged in with a 12w block ... and what do you mean by alternate device like another phone?
Ashepherdson
Yes another phone or tablet , its definitely a connection issue and I wanted to see if we could get rid of a variable, I'm also exploring some other avenues for you looking for a workaround, worst case I'll escalate this for you of course.
No I don’t just smart TVs nothing else
Ashepherdson
Okay I'm gonna ask that you do a full factory reset on the hello doorbell , if this doesn't work I think I'll have to escalate ,
Locate the reset pin hole on the back of the doorbell.
Insert and hold the pin (you can use an unfolded paperclip or a thumbtack):
At 10 seconds, the status light will blink yellow four times, and you’ll hear a countdown tone.
At 12 seconds, the status light will be steady, solid yellow while the doorbell starts the factory reset, and you’ll hear a confirmation tone.
Release the button. Your doorbell will restore to its factory settings.
Ashepherdson
Oh my goodness I didn't ask this yet, is your Bluetooth turned on on your phone?  That's how the phone connects to the nest to get setup.
Yes always on
Still nothing 😞
Ashepherdson
Okay last item ,
On your iOS device’s home screen (iOS 14 or later), tap Settings.
Tap Privacy and then Local Network. You’ll find a list of apps.
Turn on Local Network Access for the app(s) you would like to allow access to your network. This will allow permissions for your device to discover Cast-enabled devices.
Google home and nest is enabled
Ashepherdson
Okay I am escalating this for you
Meaning?
Ashepherdson
Thank you I appreciate your assistance
Hey Folks.
