09-15-2021 08:44 AM
When changing settings for a Nest Cam (https://home.nest.com/camera/{cam_id}/settings#camera-about), the location Front Porch is misspelled as "Front Poorch"
09-15-2021 08:58 AM
Neat. My path was slightly different since I am using the web, not whichever app you're referencing.
Going to Home, Settings, Spaces, then selecting the camera in question, I was able to add a new custom space with the correct spelling, then delete the old one.
Thanks!
09-15-2021 08:54 AM
That's simply how you entered it when you set up the location. Go to google home, setting, home settings, rooms and groups, select the most spelled one, and rename it properly
09-15-2021 08:58 AM
Thanks!
