Hi. Google doorbell with battery - doesn't ring on my Google mini speakers.
JohnF
Original poster: Brian Klindt
Hi. Google doorbell with battery - doesn't ring on my Google mini speakers. Any ideas what I am doing wrong ?
7 REPLIES 7
Hazyhay98
I am having the same issue
Daeh
Go to your Google and sign in.
Click on doorbell
If it showes doorbell on top alone and under it your other speakers then you need to click on each speaker you want to hear the doorbell on. Click it and go to top right corner to see info on it, it will show you if it is in Home or Home2. You want to move it to home . I don't know why some set up with home and home 2, but that was my problem.  If this is the same for you the steps I have given will work
Alan79
Same issue here. I've got a home speaker and two minis all in the sand home group as the nest doorbell (battery). Only one of the minis gives the visitor announcement. Any ideas?
Hazyhay98
I ended up resetting the wifi, taking everything off the wifi and home and it started working again.
Alan79
The old turn it off and turn it on again eh?
Aaaannnnddd it worked 😉 thanks a million. Not going to lie though I'm a little mad I didn't think to do that first.
Daeh
I don't understand, how do you turn on and turn off again and how does this get the doorbell to be heard on my mini speakers? Ease someone tell me all steps I need to do in order to set up my battery google nest doorbell with my mini speakers in my home.
Daeh
I figured it out myself, didn't use the wi fiber and off, much easier way
