12-12-2023 09:03 AM
Can you put insulation around the outside of your doorbell battery operated camera
12-12-2023 10:47 AM - edited 12-12-2023 10:47 AM
I do not have insulation on my doorbell camera and it has gone through last winter whitout incidents and I'm in Canada where it does get cold sometimes. This to say that I do not think that you need to insulate yours.
12-12-2023 10:49 AM
Oops, yours is battery operated and mine is wired.
12-15-2023 02:40 PM
@Bugsey, thanks for reaching out here in the Community. I really wish we have an accessory to insulate the Nest Doorbell. At temperatures between -20 °C (-4 °F) and 0 °C (32 °F), the doorbell can continue to work, but the battery will drain because it can't be charged. If the battery drains completely, the doorbell will shut down, and you'll need to bring it inside to be charged. If the temperature is below 0 °C (32 °F) and the battery is low, bring it inside to a warm place, preferably at room temperature. The battery can start to charge slowly once its temperature rises past 0 °C (32 °F). It'll charge faster when it warms up.
To learn more, you may visit our public article about "Cold weather battery charging behavior in Nest cameras and doorbells".
I appreciate your response, gilleslibre.
