12-28-2021 09:40 AM
I recently installed 2 nest hello doorbells the doorbell's work and the streaming feature works they ring at the location of the doorbell but the inside chime does not ring Please help
12-28-2021 05:40 PM
I’m having the same problem with iPhone. Look forward to hearing the solution.
01-03-2022 04:49 AM
Try tutningmthenchimemto the opposite of what you have. Make sure the electronic has a chime duration. Press the button a few times. Switch back to your chime type and test. Might have to do a few times. Worked with my mechanical bell. Good luck.
01-03-2022 01:52 PM
03-04-2022 09:44 AM
03-07-2022 01:23 PM
Hey Folks.
