12-20-2022 03:05 PM
Hello. So I have had the nest camera and doorbell set up in my home for close to two years. And since that time never encountered any major issues either viewing cameras and door bell on both mobile networks or mobile via wifi. A few days ago, my ability to view my cameras by mobile (cell) stopped. The cameras wont load. As soon as I switch to wifi I can view the cameras. What is even more odd is that if I am on mobile (cell) and I get a notification of movement or something, I can view that. But anytime on mobile (cell) that I open nest aware, I can no longer see anything on the cameras. very very strange.
Any ideas
12-27-2022 09:42 AM
12-30-2022 02:54 PM
@galeic it's us again. Aside from restarting your Nest Cameras and Nest Doorbell, you may also try restarting your mobile phone and your WiFi network. I would suggest you reinstall your Nest app or Google Home app. In case you have an update, you know where to find us.
I appreciate the help, Brad.
01-01-2023 04:43 PM
Hi galeic,
Thanks for the help here, Brad and Emerson.
Best
