My wired Doorbell goes offline every 2 days & it doesnt even chime when someone rings the doorbell
mvyas
I've had my Nest Doorbell since 2018 & i have it wired with the existing chime, it worked perfectly and without issue until recently. Now every 2-3 days, it goes offline & doesn't come back online unless i do a factory restart & do the whole setup again.
During the offline period, the doorbell does even ring/chime when somebody presses the doorbell.
Does anyone have any suggestions on how to resolve this issue?
2 REPLIES 2
@mvyas
Our Nest Hellos are not as old as yours, but maybe your doorbell is beginning to fail. See this LONG related thread on Nest Hellos failing after 1 or 2 years due to a failing internal battery (yes, they have a battery):
https://www.googlenestcommunity.com/t5/Cameras-and-Doorbells/Nest-Hello-Doorbell-cuts-out-when-butto...
Thanks for visiting the Community. Since this thread hasn't had activity in a while, we're going to close it to keep content fresh.
We hope you were able to get the help you need, but if you're still having trouble, please feel free to submit another post, and provide as many details as possible so that others can lend a hand. Hope this helps!
