Nest Battery Cam
BadNest
with all the new nest cams that use google home you can not share a specific device. You have to share your entire home. That is real bad.
Also Nest eliminated the live feed option that you can share with people.  This option is still available on Nest app but has been eliminated it on the google home app
notNewToThisTek
Google really should've made sure the apps had feature parity before force feeding the migration.
notNewToThisTek
Jeff
Hey, BadNest.
Sorry for the issues you're having with the Home app. As we've made the transition from the Nest app to the Home app, there have been a few bumps in the road. The intent is to have the Home app be the hub for all smart devices in your home in the future. While some features have still not come across, the Home app is continually being improved and we're hoping to see better and new functionality down the road.
That said, I understand why you're frustrated with the current experience and I would invite you to share your feedback directly with Google. From the Home app, you can send feedback and let our internal teams know about your experience. Instructions for that are below.
  1. Open the Google Home app Google Home app.
  2. At the top right, tap your account.
  3. Tap Feedback and then tap the type of device you'd like to submit feedback for.
  4. To display available emails, in the "From:" section, tap the arrow on the right. Select your email address.
  5. In the feedback summary, write a brief description of your issue.
  6. Be sure to check the box for Screenshot and System logs.
  7. To submit feedback, at the top right corner, tap Send .
If you need anything else, just let me know. Thanks.
Jeff
Hi, everyone.
Thanks
