Nest Cam indoor will not reconnect after wifi pswd change
Ceyda
I changed my wifi paswd and now cant add camera to Home App. It says they r on different wifis 😭 help pls 🙏
David_K
If you're comfortable changing your router settings, you can change your new Wi-Fi network name and password in your router's settings to be the same as the previous ones. Your camera should then automatically re-connect to the Wi-Fi.
Otherwise, follow these steps:
  1. Open the Nest app and tap the Settings cog.
  2. Select Home info then Home Wi-Fi help.
  3. Select the camera you want to update.
  4. Tap Start > Update settings.
If you don’t find Home Wi-Fi help in the app, or those steps don't work for you, you’ll need to remove your camera from the app and add it back with new Wi-Fi information. Make sure to save any important video clips before you remove a camera from the app. Once a camera is removed, all of its recorded video history will be permanently deleted. Also, if your camera is the only device covered under a Google Nest Aware subscription, make sure to stop auto-renewal (or cancel a 1st gen Nest Aware subscription) before you remove your camera from the app.
aatienza
Hey Ceyda,
Thanks for chiming in, appreciate the help @David_K. I'm dropping by to ensure if everything is covered here. Let us know if you still need help with your camera.
Archie
Jeran
Did you have any more questions or need any additional help?
Thank you,
Jeran
SteveT1
We haven't heard any updates from you. I'll go ahead and lock this thread in 24 hours. If you're still in need of assistance, feel free to start a new thread and we'll be happy to help.
Steve
